Do I have too much hp for an otherwise stock truck?
Old Sep 28, 2005 | 07:40 PM
Ian's Avatar
Ian
I'm gonna be putting in my stage 5 injectors and tapping my comp before BD dyno days, and I was wondering if my EGT's are going to be too high for my mods to be of any use, and I was also wondering how my tranny will hold up. Everything is stock unless listed in my Sig, and the truck is an auto.
Cheers,
Ian
Old Sep 28, 2005 | 07:42 PM
Lrdchaos's Avatar
your tranny won't hold it........your egts will be a little high....but it gives you a good reason for a new tranny and turbo.
Old Sep 28, 2005 | 07:51 PM
shoe's Avatar
I have a 2000 also with stage 5 jammers,comp and I can not run the comp with the injectors EGT are ok with a 5" exhaust but the turbo does not flow anough air. I am running a tripple disc TC and your stock with not hold.
Rob
Old Sep 28, 2005 | 08:29 PM
Rauschbo's Avatar
Hmmmm....
....too much horsepower....
.....too much money.....
....she's too pretty......
....(ad infinitum, ad nauseaum)......
Old Sep 28, 2005 | 10:44 PM
BigBlue's Avatar
Your tranny is going to last maybe one WOT run and that's it if it even lasts that long. Your turbo is going to look at you and laugh. To hold that kind of power your going to need a fully built tranny and at least a KSB1.
Old Sep 28, 2005 | 10:56 PM
Ian's Avatar
Ian
mhm...thats what i thought...
Old Sep 28, 2005 | 11:25 PM
rockjeep73's Avatar
My tranny wont even hold anything over about level 3 or 4 on my TST, and thats with stock injectors!
Old Sep 29, 2005 | 09:01 AM
CTD NUT's Avatar
Stage 5's and a Comp, huh? That little HY will be spitting lava from the outlet if you hold at WOT for too long. The TC will not be even remotely close to hanging to that kind of torque, either. You are stepping into the realm of big power here. A REALLY good TC coupled with a built tranny is your only option if you care about longevity. And as Blue mentioned, with that much fuel, there isn't much point in considering anything less than a full B1 or similar turbo.
Old Oct 6, 2005 | 07:22 PM
Ian's Avatar
Ian
at what point do you need twins?
Old Oct 6, 2005 | 07:32 PM
Gotlift01's Avatar
I would say when your EGT's get so out of control that it doesn't matter what size of a single turbo you have. Twins will help cool the EGT's a fair amount!!
Old Oct 6, 2005 | 07:38 PM
Ian's Avatar
Ian
ok, perfect. thanks gotlift01
Old Oct 7, 2005 | 08:27 AM
RAM2940's Avatar
Well i think after a couple long hard runs you will be calling a tow truck and getting a new tranny along with a new short block because youre going to cook the pistons. Your turbo and exhaust are to small to handle that kind of fuel and horsepower. That truck is going to have to breathe alot better(air in and air out).
Old Oct 7, 2005 | 09:04 PM
Ian's Avatar
Ian
well, I just finished tapping the comp, haven't driven it yet, so we'll see how my egts do with just that. The problem with turbos is that theyre expensive...lol. Until I can afford a better turbo I'm going to run dual 4" and a type of RAM air system...hopefully that will help a bunch.
Old Oct 7, 2005 | 09:34 PM
53 willys's Avatar
with my comp on 5x5 by the time I hit 70mph i'm at 1300 deg
Old Oct 8, 2005 | 10:47 AM
Ian's Avatar
Ian
mine must not be working 100%. I noticed its a little more ballsy but nothing huge, and it definitely doesn't heat up like yours does 53 ******...
