DiPricol EGT stuck? 300'
Old Nov 9, 2005 | 10:37 PM
Timmay2's Avatar
With the truck up and running again, i just noticed my boost and fuel pressure work nice, but my egt gauge sits right at 300, even after driving around awhile.
i go back home, check the connections on the back, everythings good, lights up.. but still just sits at 300.
So i unplug it, wait a while, plug it back in.. then it just sits at 250? go drive for a couple minutes, still at 250?
For the lights on all the gauges i tapped the dimmer switch... which i thought at first it may be using some of that power to work the gauge, however the instruction sheet says they require no power.
Im confused?
I also noticed Geno's no longer has DiPricol gauges so im wonderin if the gauges suck that bad and i got the last ones!
Any ideas before emailing him for exchange? I double checked the connection where the probe connects to the extension wire, all good.
Old Nov 9, 2005 | 10:45 PM
Timmay2's Avatar
possibly not giving it long enough to move?? 10 minutes or so and it was still around 250
Old Nov 9, 2005 | 11:03 PM
dodgezilla04's Avatar
mine would do it too, if I tapped on it, it would drop suddenly and read good for awhile, I got tired of it, emailed dipricol and they sent me a new one. works good now.
Old Nov 9, 2005 | 11:15 PM
low c1500's Avatar
If this is a thermocouple sensor (most are), then it sounds like the two wires may have shorted together at some point other than the probe tip, inside your exhaust. If this happens the gauge will read the temperature at the wire short (maybe around the manifold).
Old Nov 9, 2005 | 11:22 PM
Timmay2's Avatar
I just read some old posts about someone elses whose wouldnt go past 400...
Must be pretty common.
The connectors have offset connections so theres no way they are touching each other.
So do you have to go through DiPricol themselves or just the vendor you purchased from?
Old Nov 10, 2005 | 09:28 AM
low c1500's Avatar
By the wires being shorted together, I meant that they could have been melted together by heat (touched the manifold).
Old Nov 10, 2005 | 09:34 AM
Timmay2's Avatar
Goes straight up from probe and is zip tied to the existing wire loom along the back, so no wires touchin anything hot..
Old Nov 10, 2005 | 03:18 PM
Iron City's Avatar
Timmay, I had a similar problem, you probably read my post:
https://www.dieseltruckresource.com/...ad.php?t=76124
Geno's was awesome about sending replacement parts asap. First they sent the thermocouple, that didn't work, then a new gauge and that solved the problem.
Old Nov 10, 2005 | 03:52 PM
Nuttymopar's Avatar
On my old 1st gen. it would start off as normal but some times it wouldn't go past 500* or 600* when in fact I was pushing it hard and it should've been right up there. I took the probe out and noticed SOOT (go figure) all over the probe. Cleaned it and it would work just great. Noticed most of the few times it did that was when I was running a lot of Power Service (white bottle) through the tank. I never have measured the proper amount of PS, just pour some in so I'm sure it might have been too much.
Some times I would need to shut it down and wait till it cooled down before working again.
I know it isn't the same as your problem, just thought I would mention it. I would call DiPricol and try to get a replacement.
Old Nov 10, 2005 | 11:36 PM
Timmay2's Avatar
Emailed to ask about replacement, thankfully i dont need EGT as much as Fuel pressure..
Baja
Jan 29, 2008 08:17 PM
CTDowerTN
Nov 13, 2007 06:35 PM
powerstrokin03
Dec 10, 2006 05:38 PM
JohnnyH
Jul 23, 2004 06:59 AM
