315's on stock truck?
Old 09-25-2005, 02:32 AM
oestreich84's Avatar
Well its that time of year again to buy new tires. I had a 2" leveling kit installed, but I had to remove it because I couldnt get my truck in the garage last winter. Since then I moved into a new duplex with bigger garage doors. So at the stock ride height, will I be ok running 315's for about a month or so until I get another leveling kit, or will they rub real bad. I would try to take it easy until I get the kit installed, but I never know when I will have to go and pull my friends big old ford out of the mud. I guess I just need to know if anyone is running or has ran them without a leveling kit. TIA Joe
Old 09-25-2005, 08:33 AM
Registered
blackdiesel's Avatar
ive got a buddy with a 01.5 4x4 and he says theres no lift under his and hes runnin them jsut fine
Old 09-25-2005, 10:35 PM
drew03's Avatar
they fit just fine on my 03
Old 09-26-2005, 07:09 AM
Iron City's Avatar
they work on mine, although the fronts rub on the rear of the fenderwall if you compress the suspension while turning (or just a big compression).
Old 09-26-2005, 07:36 AM
Jason Foster's Avatar
I am running 315/70 r17 on 10 inch rims on a 2005 Quad 4X4 with stock suspension. I had to trim the front air dam and they hit on the back of the wheel well. Might be able to mash it in some or just live with it. The 2 inch leveling kit will solve it.
Old 09-26-2005, 07:18 PM
BIGHEAD's Avatar
Yeah they will fit. Just get you a 3 lb hammer & beat the crap out of the back of the fender well. Get your portable reciprocating saw & cut the plastic bumper molding. If it still hits, beat some more until you hit the door & cut some more until all the plastic is gone. My 305's hit the back & I have done the above, but only once.
Old 09-26-2005, 09:56 PM
CASMOKIN's Avatar
I would wait untill you put your leveling kit back on. No sence in performing surgery on your truck if you dont have to. My $ 0.02
Old 09-27-2005, 09:48 AM
Gotlift01's Avatar
I agree, just wait until you get the leveling kit back on!!! I'm sure you could get away for the time being if you never had any suspension flex or never made REALLY tight turns, then they might night rub much.
Old 09-27-2005, 10:22 AM
timbeaux38's Avatar
Mine rub the lower control arm at full lock ...No lift
rjordan
09-27-2004 09:25 AM
Battering Ram
04-23-2004 09:44 AM
tobyw
18
03-06-2004 06:42 AM
Fillerupsonny
12-30-2003 05:12 PM
10-02-2003 09:06 PM
Quick Reply: 315's on stock truck?
