Diesel Dynamics Stage II injectors
Looking for some info on these injectors if anyone has them/has used them?
I looking at buying a used set from a guy and we probably all know DD has been out of business for quite some time (now R&D for Edge). Are these injectors the 'Jammer' injectors Edge now sells? (Haven't heard to good of things about the Jammers)
Are these injectors EDM'd? How's the EGT's over stock? MPG? You get the general idea of what I'm looking for. Tried 'searching' and couldn't find much info.
Thanks in advance
Thanks in advance
As far as I remember, the DD2s are not EDM'd, they are extrude honed injectors. I've been running them for a long time with no problems. They definitely are old technology compared to the newer styles, but they still work well.
They don't roll loads of smoke, but they do blow more than stock. They're good for running with a bus fueling box (or programmer) with the stock turbo. If you tap the wire, you'll need more turbo.
Thanks for the info. I'm not looking to 'roll smoke', I want a clean and efficient injector. Did you notice any increase in MPG going to these injectors? I'll be changing over to a stock HX35 as well when I do the injectors.
If you're looking for a clean and efficient injector, I'd look at something like a Mach 1.6. The Mach line of injectors are good stuff. I ran some Mach 6s in mine for a while and I was impressed with how clean/efficient they were for such a large injector. I only switched back to the DD2s because I don't have the cash or time to upgrade everything else needed to run those big sticks at the moment.
The DD2s will get you by, I may have picked up a slight increase on mileage, but it was nothing major. Plus, since I had an HO pump when I originally switched, the gains were bigger since the HO pumps like injector swaps.
What other fueling mod (if any) are you planning to run? If you stick with something like an EZ or Smarty, you can get by with the HX35. If you go up to a wire tap box, you'll need more than a HX35 on the upper levels.
Can't afford the Mach 1.6's currently, have heard great things about them.
I have the Adrenaline. I'm getting the HX for next to nothing (better then the current HY) so that's why it's going on.
Thanks for the input Justin.
The DDII's I'm looking at are 7 hole injectors.
I replaced a set of DD2s with Mach 4s-- a substantial increase in size.
The M4s will actually flow more fuel before they smoke than the DD2s did.
The DD2s were a fun upgrade, but having now used the Machs, I would either go Mach or stay stock.
Hey, that rhymes
Hey, that rhymes
Been running DDII's for about 3 yrs now I bought from a DTR member. Very smokey for me (probably altitude) but controllable, never care about mpg's, they increased egt's for sure but I never ran them with stock turbo only the hybrid.
I'm @ 7,000 ft. What I meant by very smokey is that if I want I can black out (intentional smoke) an entire intersection at low rpm, some turbo lag and being in too high of a gear(lugging). For the most part they just produce a haze with normal driving in town or highway.
masonic-dodge
Dec 18, 2006 11:55 PM
crabman
Jun 14, 2003 07:58 AM
29
Nov 12, 2002 10:28 PM
