Bosch RV275's, Diesel Dynamics stage I & II injectors
Old Oct 23, 2002 | 10:56 PM
SmokinShaker's Avatar
Re:Bosch RV275's, Diesel Dynamics stage I & II injectors
Whoa there, take a breather. That's a lot of questions! ;D I'm in the same boat as you except I don't have a brand new truck :'( <br><br>I had planned on running the 275's just so I didn't get in any hassles with the ******* but that was before you mentioned the DD1's having the stock part number...you've got my attention. I'll just say welcome to the site and I'm sure you'll get the info you need. There is a lot of experience/knowledge on this site.<br><br>Ryan
Old Oct 24, 2002 | 01:00 AM
CMN_NOT_STROKN's Avatar
Well to my knowledge all of the DD injectors use extrude honed stock injectors and therefore carry the same part number as stock. They require you to send your stock injectors to them(core charge). Extrude honed is a process of enlarging the orifice of the injector by forcing a sand paper like clay through it thus enlarging it. As far as I know the RV275 injectors can be distinguished from stock. Not likely the ******* could tell but it is possible. The extrude honed stock injectors cannot be identified except by putting them on a flow bench and testing them compared to stock. I don't see a dealer checking that. As far as which ones to choose that is up to you. I would get the DD 2s but I am sure that you will need to upgrade the clutch/trans to handle the additional power. Hope this helps. If any of the info that I have given is incorrect, somebody please let us know the truth.
Old Oct 24, 2002 | 01:15 AM
Bart Timothy's Avatar
It depends upon what performance level you're trying to achieve. You can go as high as DD3s and still be able tow and have good smoke control, but run better with turbo mods. Higher altitudes and hot days will cause more smoke.<br><br>I think 275s on an ETH run real good. They add about 42 hp, and can be found for cheap.<br><br>You'll need guages if you don't already have them. They are a must.<br><br>275s and DD1s are probably all your stock clutch will handle. You can make the stock clutch last longer by staying out of the peak touque band and keeping rpms avove 2000.
Old Oct 24, 2002 | 06:31 AM
Timinva's Avatar
DTR Advertiser
I started with 275's and a month later wanted more. I installed DD3's and sold my 275inj. Power is very addicting in these engs. so be sure to get the ones you want the first time so you dont have to do the job twice. Tim
Old Oct 24, 2002 | 10:46 AM
ridofpwrstroke's Avatar
i was in the same boat, i wanted 275's but you read about all the people that want to upgrade more after they get the bombing bug. I dont want to upgrade my clutch yet(since it is only 3 months old) but with the DD2's I dont think i will have to, when i put on my box, then i will have to upgrade. Hope this helps.
Old Oct 24, 2002 | 11:12 AM
banshee's Avatar
Here's the chart of the DD website of the HP given from each of the injectors. IMO you should get the big ones to start with... you're just going to be wanting them anyway.<br><br><br><br>John
Old Oct 24, 2002 | 11:46 AM
TxDieselKid's Avatar
becarefull or you'll have to do a clutch upgrade too. the 6-speeds don't hold power as well i hear. <br><br>Andrew
Old Oct 24, 2002 | 05:59 PM
[quote author=Ascraeus link=board=7;threadid=6210;start=0#57068 date=1035487932]<br>I don't plan to put my foot into it very much or very hard. <br><br>Ascraeus<br>[/quote]<br><br>It's ok man, you can be honest with us. ;D
Old Oct 24, 2002 | 11:45 PM
You WILL eventually need a clutch with DD2s. I don't believe there's a difference between the '01 and '02 clutches. Keeping the rpms up definately helps clutch life. <br><br>I smoked my stock ETH clutch with just an PE box and a little propane - before the EZ, Comp and South Bend were on the map. Getting a good ETH clutch was tough back then.
Old Oct 25, 2002 | 11:02 AM
Mr. Poet, I dont know all the numbers and input splines but what I do know is that is with stage 2 injectors, my stock clutch is still working and no slipping. I think when I get my box I will need to upgrade.
