custom exhaust
Old Apr 11, 2003 | 06:03 PM
cummingetit's Avatar
custom exhaust
I'm thinking of installing a custom exhaust to my truck. A local guy here is a real artist when it comes to custom bends. I'm thinking of putting duals on. But not straight out the back. Run the pipes right behind the rear tires, then straight down. So you only see about 4-6&quot; of chrome tip below the fender line on either side of the truck. Kinda hidden.<br> The biggest pipe that will fit between the fender and the spare tire is 2.5&quot;. I won't be able to run anything larger. Will this be a problem with flow or EGT's? It will be 3&quot; underneath before the axle, then Y'ed and 2.5 to tails.<br><br>Thanks for your help
Old Apr 12, 2003 | 08:40 AM
Got Smoke?'s Avatar
Re:custom exhaust
[quote author=cummingetit link=board=7;threadid=13500;start=0#127125 date=1050102236]<br> I'm thinking of installing a custom exhaust to my truck. A local guy here is a real artist when it comes to custom bends. I'm thinking of putting duals on. But not straight out the back. Run the pipes right behind the rear tires, then straight down. So you only see about 4-6&quot; of chrome tip below the fender line on either side of the truck. Kinda hidden.<br> The biggest pipe that will fit between the fender and the spare tire is 2.5&quot;. I won't be able to run anything larger. Will this be a problem with flow or EGT's? It will be 3&quot; underneath before the axle, then Y'ed and 2.5 to tails.<br><br>Thanks for your help<br>[/quote]<br><br>My honest advise would be to chain the spare in the bed, then do the exhaust like you want i.e. 3&quot; <br><br>This way its a win/win situation........ you get bigger exhaust which sounds better and doesn't hurt EGT's, and you don't loose your spare from the famous &quot;frayed cable&quot; like I lost mine from! &gt; &gt; &gt;
Old Apr 12, 2003 | 11:34 AM
SjLingenfelter's Avatar
Re:custom exhaust
There is someone in our area that did custom exhaust(something he did in shop class) it comes off the turbo and goes about half way underneath the cab and then Y's off and ends up right at the end of the cab. Doesnt sound good at all.<br>Someone should talk to that boy! <br>SD03<br>
Old Apr 12, 2003 | 09:39 PM
ARAcummins's Avatar
Re:custom exhaust
I have a quad cab one ton and did just what you are talking about. I had the Muffler and resinator removed and put about a two foot piece of straight pipe in and then a y pipe made out of three inch pipe and then put three inch tails coming out behind the wheels, out the side. The three inch pipe well fit it is just a little tight. I think I have about a quarter inch to maybe a half inch between my spare and the pipe. Somewhere around 30k and no problems, I want to get the four inch pipe put on from the turbo back to my y pipe, but I haven't got around to it yet.<br>Good luck,<br>Heath<br><br>P.S. paid $350 to get all of that done at local exhaust shop with a pair of 5&quot; $80 chrome tips, not too loud running down the road untill you get on it. Just right :
Old Apr 12, 2003 | 10:21 PM
Re:custom exhaust
Is there a way you can send me a picture of your truck? To: yzguy@comcast.net<br><br>I gotta see this <br><br>Thanks
Old Apr 13, 2003 | 11:24 AM
jt's Avatar
jt
Re:custom exhaust
I have 4&quot; duals and my spare is still in place.<br><br><br>JT
Old Apr 13, 2003 | 11:25 AM
jt's Avatar
jt
Re:custom exhaust
Here is a pic.
Old Apr 13, 2003 | 11:53 AM
Re:custom exhaust
Yeah exactly, but I'm going to aim mine straight down. So you only see like half of the tips. A semi-hidden exhaust!<br><br>Your 4&quot; is on the new body style, right?<br><br>I don't really know why I was told only 2.5. 3 will fit with the right bends. hum??<br><br>Thanks for the replies guys , I post some pics when I get this done.
Old Apr 14, 2003 | 12:31 AM
Dieselhead's Avatar
Re:custom exhaust
What do you mean? I have 3&quot; duals with 4&quot; tips and have plenty of room for my spare. I have the standard bed. Here's what mine looks like:<br>http://www.cardomain.com/id/rattlindodge<br>
Old Apr 14, 2003 | 11:21 AM
Mopar_Mudder's Avatar
Re:custom exhaust
JT<br><br>How about a little info on them system, I like the look of it. What size pipe to the muffler?<br><br>What kind of muffer?<br><br>How much did it cost?<br><br>And most important, how does it sound........<br><br>Looked on their site and didn't see any info for the new trucks.
mchydro
15
May 4, 2006 07:33 AM
SylvanLaker
Mar 27, 2006 12:47 PM
Palmetto_kid
Nov 28, 2005 11:07 AM
ox
Jul 7, 2003 02:52 AM
