crankshaft position sensor not the prblem
Old Feb 11, 2009 | 02:21 PM
CaledoniaOutlaw's Avatar
my truck was showing a code , a bad crankshaft position sensor, I replaced it last night cleared the code and now today it poped up again . Looks to me like i just replaced a $46 sensor that didnt need to be replaced, What other posible problems can trigger that code? Thanks Dan
Old Feb 11, 2009 | 04:07 PM
Dinner's Avatar
Probably a problem with the wiring going to and from the Crank Sensor. Could be near the sensor, or up somewhere along the bigger harness perhaps.
Old Feb 11, 2009 | 04:12 PM
00 CTD's Avatar
Did the old sensor have any kind of groove worn into the end of it?
If there is a groove in the old sensor , then the tone ring on the crank is loose.
Old Feb 11, 2009 | 06:04 PM
98.5Hotrod's Avatar
00 CTD is right. Check the end of the old sensor if there is a groove in it, its time to drop the oil pan and repair the tone ring.
Old Feb 12, 2009 | 06:40 AM
no ,there wasnt any wear on the old one i saved it because i think its still good. on the computer print out it says to check trigger wheel for damage , is that what you mean when you say tone ring ? What is it?
Old Feb 12, 2009 | 08:18 AM
dzlfarmboy's Avatar
Yeah there is a tone ring that bolts to the crank inside the pan that the crank sesor reads off of.
Old Feb 13, 2009 | 05:16 AM
00 CTD's Avatar
The tone ring determines where #1 TDC is. Normally don't have any problems with them unless the screws come loose and it starts wobbling around. A groove cut into the end of the sensor is a tell-tale sign that it's loose.
Since the old sensor looks OK, might want to check the wiring. Could be moisture in the connector, corrosion or spread socket in the connector.
Old Feb 13, 2009 | 06:43 AM
well i thought the sensor looked fine until I cleaned it up and took a closer look at it last night and found some hair scratches on the end, so i guess it is the tone ring. Has any one had to make this repair, and have anytips or tricks?
Wild Bill
Jan 21, 2005 03:35 AM
James Andres
Dec 20, 2003 04:42 PM
Two Dogs
Jul 11, 2003 09:12 AM
ATEAV8GN
Apr 1, 2003 08:03 AM
