Cowl hoods
Cowl hoods
Does anyone use a cowl induction hood, and if so how does it work with our diesels? They look good but does it have any functionality to it? Found one by REFLEXXION looks good but no info on funtionality, any input would be welcomed.
Mine has no function what so ever. Looks cool though.
http://www.turbodieselregister.com/u...=17127&width=2">
http://www.turbodieselregister.com/u...=17128&width=2">
Justin
Justin
The place to look is called Good Hoods (or is it Hoodz?) Either way, the name sounds cheesy, but the product is nothing short of BAAADDD!!!! You will like their setup, and they even have a forced air induction channel which pushes the air in your intake. This can really boost performance and cool your engine at the same time.
The REFLEXXION hood is a functional hood I am going to make a ScottyII type filter holder for a custom built filter for my twins. I will pickup air from the stock fender opening, the 4" hole from a former ScottyII and a 4" feed from the hood.
Bruce
Bruce
"3 stages blown diesel, 1-hx40, 2-s400s, 3-gmc4-71rootsblower, propane, water/meth, nitrous, 5 1/2 inch exhaust, 150mph@5000rpm"
Whoa!!
.....What is this insane engine installed in?!?!
......What engine is it?
Whoa!!
If you want a functional one (not sure about the others but this one definitely is). If I recall correctly the maker is Doug Holfeldt in Idaho. AirBulldog Hoods
http://dpofutah.tripod.com/id39.htm
goodeyesniper75
41
Apr 10, 2011 09:40 PM
crossy
Jul 25, 2005 08:17 PM
