Could I spin This?
Old Jun 18, 2012 | 12:32 PM
Schneider's Avatar
Could I spin This?
I have an HT3B that I bought off this guy and it came with a 32cm housing and a 23cm housing. Would the 23cm housing be good as a single turbo or would it be too laggy and not good spooling at all?
Old Jun 18, 2012 | 01:06 PM
95ram's Avatar
I wouldn't run it as a single. That's a big turbo to be driving on the street. If it were a pull truck only I'd try it. It would be a good bottom turbo in a set of twins.
Old Jun 19, 2012 | 11:44 AM
Mike Holmen's Avatar
The Guru
What tweaks you running in the P7100 pump? I would run at least 5k gsk or more, so you get abit of useable rpm on the turbo.
I think that turbo would work better as a primary turbo in a set of twins under your 64mm. I would find a different turbo that has a smaller turbine housing. That turbo is going to be a laggy beast and smokey.
malibu
Jan 30, 2003 09:40 PM
NWDave
Jan 25, 2003 06:03 AM
Nevada
Dec 28, 2002 11:47 PM
kingofdodge7131
Dec 14, 2002 09:08 PM
USMC64-70
Nov 10, 2002 02:59 PM
