Cooldown Timers..............
Old Nov 8, 2004 | 05:33 PM
Ricktye's Avatar
Question Cooldown Timers..............
Anyone know if Howard Vanfleet is still making the Cooldown timers?? I want to buy one, keep sending him Emails, but no replies.........
TIA
Rick
Old Nov 8, 2004 | 06:10 PM
phox_mulder's Avatar
Check the DTR store.
http://store.dieseltruckresource.com/
phox
Old Nov 8, 2004 | 06:33 PM
Ricktye's Avatar
Thanks, phox. The reason I wanted to get a hold of Harold, was to see if he can add one more switch to the circut to allow indefinite run (with high idle set.) I think it will be an easy mod for him, but..........
R...
Old Nov 8, 2004 | 08:10 PM
INJECTOR JACK's Avatar
BD Diesel has come out with cool down timmers they also have one that works off your pyro. The engine will shut down when the pyro reachs 300 degress.
Old Nov 8, 2004 | 09:17 PM
Ricktye's Avatar
Thanks for the info on the BD timer. Nearly twice the cost tho and I don't think I could add the "indefinite run" switch to that one........
R...
Old Nov 9, 2004 | 09:27 AM
infidel's Avatar
Harold travels quite a bit and doesn't take a computer with him.
Call him at 208-459-7849 it will patch though to his cell if he's on the road
Old Nov 9, 2004 | 05:21 PM
Harold - Howard
Potayto - Potahto
phox
Old Nov 9, 2004 | 07:25 PM
Ricktye's Avatar
Whoops, you're right, it is Howard.................
R...
Old Nov 9, 2004 | 11:51 PM
infidel's Avatar
Guess were talking about two different people, Harold Brower also sells timers.
Old Nov 10, 2004 | 06:54 AM
Ricktye's Avatar
infidel........... C ur PMs......
R...
Old Nov 10, 2004 | 12:40 PM
BigBlue's Avatar
So confusing.
Old Nov 10, 2004 | 10:12 PM
BDR2500's Avatar
So are cool down timers really worth spendin the money on?
Old Nov 10, 2004 | 11:14 PM
KATOOM's Avatar
That depends on the amount of patience you have.
Old Nov 11, 2004 | 06:34 AM
infidel's Avatar
Depends on who you listen to.
Cummins says just shut it off with no cool down unless you've been pulling a load.
I've been following their advice for over 400k without a problem.
Old Nov 11, 2004 | 06:35 AM
jthorpe's Avatar
DTR Founder
I've been doing the same thing. I'll usually let mine cool down for about 20 seconds before shutting down. No issues. If I'm towing, then I'll let it go five minutes before I shut down. I've also had no problems.
