Controling EGT's
Old Jun 30, 2004 | 09:15 PM
97RAM's Avatar
Unhappy Controling EGT's
OMG - what a differance the Mods made to my truck.
The only problem is I can peg the Pyro at 1600 deg prety darn fast. What do I need to do to keep these under control (besides keep my foot out of it )
I had a #10 plate put in and pushed full forward and then backed off 30k. I also added a 3kGSK with a 4" duel exhaust.
Any suggestions??
Cheers,
Ron
Old Jun 30, 2004 | 10:21 PM
bmoeller's Avatar
Bigger turbine housing, or a different (bigger) turbo.
Old Jul 1, 2004 | 03:10 PM
halerazor's Avatar
get an air intake, i couldn't get enough air with a k&n filter in my box. vacuum gauge was buried with my #6 plate. i bought a afe megacannon and now have plenty of air
Old Jul 1, 2004 | 06:01 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
htturbo (high tech turbo) in utah will modify your HX35 to take a 60mm compressor wheel (same as an HX40 wheel) match that with a 16 or 14wg exhaust housing and you can cool those EGT's pretty well
Old Jul 1, 2004 | 06:25 PM
infidel's Avatar
Call High Tech Turbo, they'll set you straight (801) 304-0700
Old Jul 6, 2004 | 09:48 AM
bowar09's Avatar
Muted User
What kind of boost are you getting from your turbo? My dad had the same problem with his truck and he could only get about 20 -25 lbs. of boost. He had a hose come off part way on the bottom of one of the hoses by the turbo. Had it put back on now the boost is up to 30 + psi. and his EGT are way down to about 1050 on a long hard pull up hill.
98 12 valve no modes except TAG
Old Jul 7, 2004 | 04:12 AM
HOHN's Avatar
I'd back the plate off just a hair more.....
Justin
Old Jul 7, 2004 | 02:11 PM
Haulin_in_Dixie's Avatar
Scotty II and ported ATS
Old Jul 7, 2004 | 05:00 PM
berner's Avatar
You could try to adjust your gov lever arm. The directions are on Piers website. Lifting the arm up a bit will cause it to cut back the fuel a little sooner and "should" lower your higher RPM heat. It will also give you a bit more bottom end. Be careful though as you'll make lots of power when your trans oil pressure is low.
Old Jul 7, 2004 | 10:39 PM
97RAM's Avatar
My boost is fine, I get a max of 32. I also had a high flow air filter installed and I drilled five one inch holes in the box.
Baker's Diesel quoted me $550 for the hybrid turbo installed, I will call hi tech turbo and get a price before the end of the week.
The tech at Baker's Diesel said the hybrid would reduce my egt's by about 150 deg so it might take backing off the #10 plate to make up the rest.
The only concern with the new turbo is frying the stock tranny. I've been getting some chatter out of the TQ converter (when I try) but it's real easy to stay away from it with right foot control. The new turbo might push me over the top.
I know I did the upgrades backwards but the tranny will come sometime next season.
Cheers,
Ron
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
Hummin Cummins
Mar 20, 2003 07:20 PM
