Compound Questions?
#76
For example, let's say you have 150F intake horn temps with a single charger that flows 53lb/min at 2900rpm. If you take that same single turbo, mount it in the upper position of a compound setup, and feed it with a PR of 2, IF you can keep the intake temps in the horn at 150, you will actually DOUBLE the mass flow! That's right, you now have over 100lb/min going into the engine!
Who would have thought that a turbo as big as the GT45 would be a great primary for even a lowly stock turbo??
If it will work so well with the stock charger, why would we use something smaller?
jmo
jmo
You can't build an "efficient" set of twins for big power and for great towing. This is simply because the smaller secondary needed for towing response will be too restrictive to let the the primary deliver the goods. If you want a twins setup that will make 800hp on fuel only, you can't do it without inducing some lag.
A twins setup with a smaller secondary and larger primary will give you a little more of each-- faster spoolup when you first get going, lots of air when you need a little more. But it can only deliver so much because it can't push the primary very hard (the small turbo limits flow). So if you want more power with a setup like this, just swap the top charger to something bigger, and now the same primary that made ~600hp (stock charger) can now make ~700 (htt62 on top) or ~800 (htt66 on top)
Your complaints about being "off boost" like most performance turbos are well founded. They simply aren't optimal for towing. They can be used for towing in many cases, but they require some compromises or adjustments.
jmo
jmo
Of course, the secondary turbine would have to flow/bypass enough gas in relation to the primary compressor.
The point is, the key to power production with turbocharging is proper thermal management.
#77
Jim, I think for our purposes gas flow and air flow are one and the same. The laws of partial pressures apply here, so I can't see why ideal gas calcs wouldn't get you within 99% of actuality. That's good enough for me.
The formula from DF doesn't seem valid to me because the total boost would be a function of PR2 (which isn't in there) as well as intercooling temp drop (which also isn't in there).
The formula works because it determines the boost value that PR1 = PR2. Knowing the boost, then one can determine PR1 and PR2.
The CAC temperature drop is after both compressors.
The CAC inlet temperature I find useful for comparing different compressors, twin vs single, PR1 vs PR2, psi vs psi, configurations etc.....
Jim
#78
For example, let's calculate the mass flow for my truck at 1800 rpm. Assuming .95 VE, I get 177.6 CFM, which is 13.5lb/min. Can I spool a Stg 3 Garrett GT37 with this setup? The turbine map says the GT37 needs 20 lb/min to even get on the turbine map at a PR of 1.25. It would appear that we can't spool this turbo.
Yet we know from many accounts that that this turbo will very easily spoolup, and much earlier than 1800rpm.
How can this be? Where are my calculations wrong?
First, we didn't "correct" the gas flow to account for EGT. At 800F, our 13.5lb/min turns into 21lb/min.
So what to make of the turbine map? According to my "calculated" spoolup on the turbine map, our corrected 21lb/min of engine-only mass flow should only generate 1.25PR at the turbine, or about 3.5psi of boost onthe cold side, assuming 1:1 for MAP:TIP.
I was going to to a Turbine 102, but to simplify things. You are correct, a turbine relies on mass flow to do work. In the simplest turns it needs mass flow and a differential pressure. The differential pressure is much more effective because the gas is hot and much more greatly resists depressurization.
This is why corrected gas flow works so well I hope I understand. It corrects and more accurately standardizes the mass rate for all conceivable gas temperatures and inlet pressures / differential pressure. The TDP for your example above is bascially zero so the PR is basically 1. In fact, is the turbine itself doing any net work because the compressor is not making any boost?
Now, lets add some fuel, make some Hp and get your turbo spooled....
Jim
#79
jmo
jmo
#80
DD--I guess in order to have meaningful discussion on your particular tangent, we'd have to accurately define what is "efficient" and what is "towing well".
The day may come where we find a good way to reliablu retrofit VGT into a compound setup. But that day isn't here yet, so we aren't going to the moon. Unlike the moon trip, this isn't a lack of technology-- it's that we can't figure a way around the laws of physics.
For example, I can find way to exert more force on turbine wheel, make it have less intertia, reduce CHRA friction and all that, but in the end, it still has mass, it still needs a certain amount of mass flow, and I can't get around those obstacles completely.
If you're going to push enough fuel for 700hp, I'd consider an 85 or 88mm inducer size primary. The 62mm secondary should flow enough to help get it spooled. You'd be surprised just how a slightly larger top charger allows a significantly larger primary to be used.
#81
The Guru
What kinda of truck is it going on p pump, vp or cp engine? What gears, tire size, do you tow? If so how heavy? What size of exhaust you planning on using? You shifting gears automatically or with a stick. As Hohn, stated you should go as big as you can manage for a primary. The S400, 74mm inducer is a good choice. Its rated to 500 to 800 HP out of air werk catalog. You can tweak the turbine housing via math or just try it out and see how it works. I find that the math will just get you into the ball park area. How hard you drive and how much load does the rest. I tow, so me personally I like the larger A/R ratio on the turbine housing, larger inducer and large wheel sizes (more air, less Pratio) and sometime less interia mass. Managing egt's is important. As Hohn stated, most of the time you only need a Pratio less than 3:1. Most large turbos do that easily.
#82
Intercooling is an excellent way to raise charge-air cooling efficiency to where enough air for big HP can be delivered by "towing" twins. If a primary operating at a 2:1 PR pushes 100*F air through an IC to a secondary operating at 3:1 PR, I would expect the hot & cold sides of the CAC to be 350*F & 125*F, respectively.
The "Total Boost" DF is refering in the formula is actually CAC inlet pressure. Still, if he assumes a negligable pressure drop across the CAC and then given that, the CAC temperature drop only effects mass flow rate not total boost.
Jim
Jim
CAC inlet temp is useful, but not that useful. The same PRs with the same efficiencies will yield the same result, whether it's one stage, two stage, or three stage compression. For example, a single stage at PR4 and 70% gives the same result as two stages each at PR2 and 70%. Of course, finding a compressor that can pull off 70% at 4:1 is pretty rare.
There's just no getting around the fact that if you want to flow a large mass of air into a small, low revving engine, you have to have a lot pressure to cram the air in there, and you have to have a ton of intercooling CAC capability to recover the the density you lose from the compression heating.
I think you forgot to add fuel? Your corrected gas number would be 1-4 lbm/min higher. Your example assumes you are turnning the engine via a external source and you just want to focus on gas flow through the turbine?
Jim
Jim
What is the definition of work done by a turbine? The primary doesn't have to be making boost to be doing work. To make boost, it has to be doing ENOUGH work. If the secondary is demanding 40lb/min, and the primary is only supplying 20, then it's not doing enough work, even if we measure a slight delta enthalpy across the turbine.
Because of the staged nature of the compressors and turbines in a compound setup, though, I think it's safe to postulate that if you measure any PR more than 1.25 or so, you will have positive pressure in the cold pipe.
jmo
#83
No assumption on the compressors' efficiency - just some empirical measurements: HE351 @ 45psi = 350*F at CAC inlet, Super B over S471 @ 60psi = 500*F, charge air temps in air/water IC cooled to 128*F with 100*F water and down to 87*F with 48*F chilled water.
So, it's feasible to supply the secondary compressor with pressurized air at @ ambient temperature; which is then further compressed at it's PR into the CAC to regain some of it's lost density... the HPCR CAC lowers the temps 225*F across it on a hot summer day.
OEM CAC has ~2psi drop across it, quality aftermarket is ~1psi...
#85
The Guru
XLR8R, you planning on using a interstage cooling on your twins? A liquid to air intercooler will mount nicely on the passager fender and you put a liquid tank and pump into the bed. Forget about using engine coolant, as your just heating up the air. My next set-up, I'm trying it out and see if it affects turbo spool-up. NOS, is the easiest way to cool off the air the leaves the primary. My spearco, hardly made any changes to egt's. It improved air flow, some.
#86
Yes - the battery is going back in the toolbox with the 10 gallon water/meth tank. Trying to find a suitable core to use for the IC; haven't decided on it's radiator location yet, since I'm thinking of using coolant chilled by R134A.
NO2 won't do except to light the primary on the dyno, since this truck will still tow (that's why I need an IC)... Nathan got a pretty good laugh when I told him what we're doing!
#87
Doesn't Spearco have separate cores you can buy, and then configure the tanks yourself?
I agree that a small nitrous shot in the cold pipe would be the best way to go as far as true "inter"cooling, but even some water or water/meth would be beneficial (high latent heats of vaporization).
#88
The refrigeration coil running through the IC's water jacket will need an orifice at it's inlet, and the coolant's thermal mass should be able to handle the heat load from the primary compressor long enough to Git-R-Done.
I will "bank" BTU capacity in the IC and expend it as quickly as possible at WOT... otherwise, the IC shedding heat to it's radiator at ambient will help full time.
I've found a number of core sources, but the economical ones don't have much in the way of specs.
Anyone ever heard of/dealt with Treadstone?
#89
The Guru
I found lots of liquid to air IC on the net for 1000hp range that will fit under the hood. You don't want too big as it will start to hurt your spool-up. I have two different sizes sitting on my bench at home just waiting for time to burn some wire. I want to put mine on top the passenger fender close to the primary. The lenght to the secondary is short as well. 3 1/2in and out so it be can't restrict air flow to much. I want to keep my batteries under the hood. I still use my box for work stuff.
commtrd
74
05-16-2014 08:44 PM
Robert Venable
34
12-11-2003 03:17 AM
