Component door speakers
Old Dec 12, 2004 | 11:18 AM
MNorby's Avatar
I aquired a set of componenct speakers in a trade and plan on installed them in my doors. I've been trying to read up on the best way to install them. I will be amping them with a 300watt amp. First thing is how to mount them in the stock 6x9 holes, should I take some aluminum or something and make a plate to bolt into the stock hole and cut holes for the new speakers or what? Also thinking of sound deadening the door at the same time, any tips on that or suggestions? Thanks.
Old Dec 12, 2004 | 01:20 PM
msing's Avatar
When I installed my CDT 6.5 I used 1/2 mdf to make a plate and mounted the6.5s in that. For sound deadening I used no name dynamat put it on the outer door skin and inner frame used about 8sq feet in each door made a big differance. Used alcohol to clean the door up so deadener stiks go.
Old Dec 12, 2004 | 09:55 PM
edwinsmith's Avatar
If you can't find one, make an aluminum box out of .060 sheet to enclose the back of the speaker. Seal the box with RTV and line it with sound absorbing foam or felt padding at least 1/2 inch thick.
This will stop the back sound wave from coming around the front and cancling some of your bass response. Also, try to find anything in the door that rattles or it will drive you nuts.
Edwin
Old Dec 13, 2004 | 06:27 PM
ratsun's Avatar
I used a piece of 1/4" hardboard to mount the components on. this needs to be mounted inside the door skin or as set of good drivers will slap the inside of the door panel IMHO I dont like the sound from tin enclosures so I use plenty of sound deadener like Brown Bread, Dynamatt on both the inner and outer skins, this will also eliminate any rattles. You will love the upgrade. I dont have any pics of the doors but theres a few of the amps and sub box in my photos check them out.
Good luck.
Old Dec 14, 2004 | 12:35 AM
MNorby's Avatar
Thanks for the info.... will hopefully be installing these in the next couple weeks.
Old Dec 14, 2004 | 02:13 PM
greenwing's Avatar
ratsun,
did you build that subwoofer box? That's pretty sweet. If so... could I get some dimensions from you?? I don't really want to spend the $$$ on the MTX Thunderform box, I'd like to build a box just like you have. I don't know if the dimensions would be exactly the same or not ? My truck is an 01...
Thanks,
-Ryan
Old Dec 14, 2004 | 02:54 PM
ratsun's Avatar
Originally posted by greenwing
ratsun,
Thanks,
-Ryan
I will be taking the back seat out these days off, so I will take some measurments and PM you.
Old Dec 15, 2004 | 02:01 PM
greenwing's Avatar
Ok, thanks
Strjock81
Jan 8, 2010 10:46 PM
ID2500Ram
Sep 27, 2008 02:01 AM
Dave88LX
Aug 3, 2005 03:35 PM
BigBlue
15
Mar 19, 2003 03:14 PM
