comp freezing up
Old Jul 21, 2007 | 10:19 AM
olwhitey's Avatar
comp freezing up
have any of u with the comp box ever have it freeze up while u are driving where it wont adjust or turn off or even work til u restart it. and also the past couple days the red lights on it would dim and act like it wasnt getting power or something and then i would tap the box and it would light rite up then. does this mean there is a loose wire inside the box? thanks, any input wanted!!!
Old Jul 21, 2007 | 11:08 AM
R.T.D.H.S.P.'s Avatar
Sounds like a bad connection at the plg in on the back of the Comp or posibly a bad ground on the actal harness. Where did you run your ground wire??
Old Jul 21, 2007 | 06:07 PM
00sport's Avatar
mine after leaving key in on postion at sonic for 20 mins. froze up kinda. only the last light was lit and it was in stock mode. killed and recranked and it was fine.
i think somethin is wrong with my truck or the chip itself cause i drove a buddys truck with just an edge ez on it and his would spank mine with the comp on highest level- currently investigating this- any ideas anyone
Old Jul 22, 2007 | 12:49 AM
Beast2B's Avatar
make sure the ground is in perfect condition. i grounded my comp to the driver's side fender (same screw as an existing lead to the battery negative terminal). that fixed some gremlins with my comp.
appydriver
Sep 25, 2006 10:32 AM
SSminnow
32
May 3, 2006 04:07 PM
danram11
Aug 1, 2005 05:36 PM
KATOOM
Jan 9, 2005 09:01 PM
