Comp and codes
Old Nov 26, 2003 | 04:36 PM
Willyzao's Avatar
Comp and codes
Was shutting down the truck the other day and noticed that my comp box was seized up, I couldn't adjust the levels or turn it off. I checked for codes and got these:
P0500 No Vehicle Speed Sensor Signal
P1693 DTC Detected In ECM Or PCM
I didn't notice anything strange while driving it, and after I turned the truck off and turned the key back on the comp was back to normal. Any ideas what happened? Does anyone know what caused the P0500?
Old Nov 26, 2003 | 05:04 PM
Fishin2Deep4U's Avatar
Re:Comp and codes
Double check your ground.
Dave
Old Nov 26, 2003 | 05:57 PM
marksmith's Avatar
Re:Comp and codes
Been roasting tires lately? I get those two codes when I put on a smoke show. They seem to reset themselves after a few startups. As for the comp being screwy, did you check your codes before you noticed the box being screwy. If I check for codes and then start my truck up without turning it back off first, the box stays "frozen" until I turn it off.
Take care
Mark
Old Nov 26, 2003 | 08:15 PM
Ramflasher's Avatar
Re:Comp and codes
I have had my drag comp for about a year now. It did that "freeze" thing to me once, reset when I turned the key off, and has not done it since. On mine, level 1, 3, and 5 were lit up, and I could not adjust it or turn it on/off.
Old Dec 1, 2003 | 11:22 AM
Willyzao's Avatar
Re:Comp and codes
[quote author=marksmith link=board=7;threadid=22898;start=0#msg214609 date=1069891056]
Take care
Mark
[/quote]
Thanks Mark, that's gotta be what it was! I spun the tires for the first time ever last weekend, then on Monday when I parked the truck I noticed that the comp was frozen on level one. I couldn't turn it off or adjust levels. I shut the truck off, then checked for codes and got the 0500; thought the codes were comp-related, but that must have been from the weekend when I was spinning the tires. Thanks again; now if I could just figure out why the comp froze. BTW, after I turned the truck off and turned the key back on, the comp was fine and has been fine since.
Old Dec 1, 2003 | 01:37 PM
hellotbone's Avatar
Re:Comp and codes
Mine was freezing all the time then I just turned the key off and restarted and all was well. Sent it out for the Drag Race upgrade and the new firmware no tests yet.
Old Dec 1, 2003 | 01:45 PM
chuck3's Avatar
Re:Comp and codes
Mine did that off and on for allmost a year, finally had it replaced. 8)
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
BigBlue
Mar 22, 2005 06:16 AM
CTD_Neil
Jan 12, 2005 06:07 PM
