Comp box/check engine light
Old Apr 2, 2007 | 07:32 PM
MARKY MARK's Avatar
Update
Well, finally had a chance to check the connections to the comp. I unplugged all connections and cleaned them with electrical connection cleaner and reinstalled the comp. Right off the bat as I started driving, the check engine light came on and I lost my tachometer and it revved up and down at the first stop sign. I put it in neutral and gave it some fuel to keep it from dying. While the tachometer was dead, the comp was not giving any extra power. Felt like stock. After a few stops at lights and keeping a higher idle, the tachometer started working and all was fine except the check engine light stayed on until later in the day. Once the tachometer started working, I had the comp power back.
Would a faulty MAP sensor cause this problem? What size socket is need to take the MAP sensor out? The prongs on MAP sensor itself were the only connection I didn't check.
Mark
Old Apr 3, 2007 | 08:14 AM
MARKY MARK's Avatar
Anybody have ideas?
Mark
Old Apr 4, 2007 | 09:20 AM
MARKY MARK's Avatar
After using the search feature here, I've come to the conclusion that the crank position sensor is the culprit with my truck's problem. I'm picking one up today and installing it tonight.
Mark
Old Apr 4, 2007 | 03:28 PM
Big Blue24's Avatar
I second the Crank Position Sensor!
Old Apr 4, 2007 | 03:43 PM
MARKY MARK's Avatar
Not one in stock out of 5 parts places. Had to order it and will be here tomorrow morning. Cost was $62 + tax.
choppers555
Oct 16, 2007 12:29 PM
bwarning01
15
Aug 24, 2007 09:19 PM
CTD2001
May 10, 2005 09:06 AM
madbomber
Nov 15, 2004 05:07 AM
hellotbone
Jul 12, 2003 12:58 AM
