comp and 275s
Old Feb 4, 2005 | 12:18 AM
caper's Avatar
comp and 275s
I have a comp (no wire) and am about to install 275s, I,m worried about hurting my clutch , just wondering if I leave my comp on less agressive levels like 1-1 or 1-2 will I be ok. My logic is that if the comp doesn't kick in untill 15 or so pounds of boost or so that will mean my rpms will be up at that boost level and therefore the engine won't be lugging when the power comes on. From what I understand its easy to slip clutch in low rpms. Can anyone make sense of that and please tell me if I'm having a pipe dream. Thanks
Old Feb 4, 2005 | 10:08 AM
BigBlue's Avatar
Your clutch should handle that nicely. Just leave the wire untapped and turn the comp on 2x2-3x3 and you should be good.
Old Feb 4, 2005 | 10:10 AM
Whitmore's Avatar
Every clutch will handel it differently, my oem clutch gave out with 275"S and just an ez
Old Feb 4, 2005 | 05:29 PM
Sixpack's Avatar
DITTO! It lasted until the first 1600 rpm romp to the wood!
Old Feb 4, 2005 | 05:36 PM
CTD NUT's Avatar
Old Feb 4, 2005 | 11:16 PM
caper's Avatar
Ha HA that was funny Sixpack , I guess all those guys that told me an ez and 275s "are a great ,safe towing combo" were full of it. I guess my next question now is ,the CON O or the CON OFE??????? Which one is better and whats their prices???
Old Feb 5, 2005 | 12:18 AM
Sixpack's Avatar
First you need to figure out how much hp will make you happy. After talking to Peter (South Bend) and Rod Snaith I decided to do the MU1947 Con O. I'm not looking to sled pull, drag race or have the fastest truck in town. I just wanted giddyup when pulling my 5r. Now tomorrow I'm installing a set of Don M's Mach 1.6's. That should keep me happy for a while.
Price wise there was a $200 difference, $700 vs $900 for the OFE. They're great clutches! Good luck, Phil
On edit: The Con O for the ETH is rated at 350hp/700ftlbs
The Con OFE for the ETHis 450hp 1000ftlbs
drcook
Sep 10, 2006 02:50 PM
TurboPirate24v
Feb 17, 2005 08:08 AM
rshelton88
Jun 13, 2003 03:24 PM
rshelton88
31
Jan 10, 2003 09:25 PM
