clutch replacement
Old Feb 23, 2005 | 12:43 PM
Fishinghaoliboy's Avatar
clutch replacement
It's time to replace my clutch. The throw out bearing is making a little squeak now and then. What should I expect to pay for a new clutch, pressure plate, and throw out bearing? Should I put a heavy duty clutch and plate in? Here in Hawaii I am restricted to NAPA and my Dodge dealer for parts. I would like to change the plate in the pump so should go to a heavier duty I suppose. Suppliers on line that anyone likes?
Old Feb 23, 2005 | 01:14 PM
rharveysr's Avatar
Why cant you order a Con OFE clutch from South Bend Clutch????
Rick
Old Feb 23, 2005 | 08:36 PM
New clutch
I guess I could just wondered what everyone was using and approximate cost. I used to live in Fresno so if I still lived there then this would not such an issue. I guess you have been getting the water this year.
Old Feb 23, 2005 | 09:29 PM
cumminsdriver635's Avatar
Depending on the kind of power you are going to make, the NAPA clutches are good. My buddy put one in his 95, and it was supposedly a "heavy duty" NAPA clutch. He has a fuel plate, 3k GSK, and 370 injectors, and its holding great so far. Im sure it will eventually slip with the way he drives it, but i am REALLY impressed by that clutch so far. He is always hammering on it, and doing burnouts, and power braking it, and stuff, and he hasnt had it that long, but it doesent slip any yet. Seems to be a great clutch. I MIGHT be able to get the part # if you're interested.
Eric
Old Feb 23, 2005 | 09:46 PM
high country's Avatar
anyone try the centerforce dual friction jobby?
Old Feb 23, 2005 | 10:20 PM
Sure any help would be appreciated
Old Feb 23, 2005 | 10:27 PM
Got Smoke?'s Avatar
Don't walk away from a centerjunk RUN!!
I'm sure if Dodgeman01 reads this thread he will chime in. He had a Dual Friction centerjunk for about a month before it started slipping. He has a small 160 pump 5spd 94 2500, and at the time it only had Bosch 300 injectors & a #10 plate. The centerjunk Co. said "TOUGH!"
There's only one clutch in our (mine & Aaron's) eyes now-a-days......South Bend!
Old Feb 23, 2005 | 10:39 PM
jimjawz's Avatar
my south bend holds awsome in 5x5 at 50 pounds of boost. have had it for about year now. But the normal second gear launch can be kinda jerky.
Old Feb 23, 2005 | 11:38 PM
600 Megawatts's Avatar
Muted User
LUK Corporation, cerrametallic upgrage clutch. Part #05-117. Holds 1,000 Ft*Lbs and costs $546, its all brand new and is made by an actual clutch manufacturing company, not a rebuilding company.
Kevin
Old Feb 23, 2005 | 11:57 PM
Muted User
Whooops, just noticed you have a 96' sorry.... dont think that part # will work.... yours is a 5 speed isnt it?? If so, No good deal with LUk, since you have to buy a new 13" flywheel to go with the cerrametallic and that makes the cost prohibitive ($989 total)......
oh wait .....thats still $200 cheaper than a 13.25" con OFE with flywheel exchange.... Well If you dont EVER tow more than 8,000 Lbs though, (who doesn't and owns a CTD I am not sure..) they say you can get a 12.25" Con O for $648 using your stock flywheel.........hummmmmm ...... isnt that just cute..... whatever...
Sorry, I know we are confusing you now.... Let us know what you do with your truck, how you drive it and what future mods you may make to it to help us help you..
Kevin
snakefarmer
Dec 23, 2004 10:11 AM
Paintpusher
Jun 25, 2004 06:05 PM
joking
Jun 2, 2004 05:36 PM
snow104
Sep 13, 2003 03:12 PM
joel
May 7, 2003 10:12 PM
