Check your bolts!!!
Old Sep 16, 2008 | 11:09 PM
Hodges4x4CTD's Avatar
Check your bolts!!!
Just a heads up, check the bolts on the front cover of the injector pump gears. It's located on the front of the engine just behind the fan belt. Dad in law is a diesel mech. and just finished fixing one where the bolts vibrated loose, cover came off, dowel pin on the gear slid out and BAM! nearly 2 g's worth of damage (parts and labor). A 10mm wrench and two seconds can prevent this from happening. He said it's more common on 2nd gens and early 3rd's.
you can find a pic in the 3rd gen engine section "Just a heads up to save $$$"
Old Sep 17, 2008 | 11:42 AM
smokinram99's Avatar
thanks for those info! I'll check mine soon..
rob
Old Sep 17, 2008 | 01:30 PM
Mike Holmen's Avatar
The Guru
If you torque up the bolt properely as per the book and use red loc tight on the injection pump shaft threads, you shouldn't have an issue with the nut coming loose.
06RAM2500
Dec 11, 2011 10:30 PM
Joe T
Jul 9, 2007 06:32 PM
