Changing sway bar links
Old Oct 3, 2013 | 08:24 PM
Silver R/T's Avatar
I want to change out sway bar links on my truck. Does it require removal of entire sway bar to get them off/on or can I replace them with the sway bar still mounted to the frame?
Old Oct 4, 2013 | 08:45 AM
dubc2323's Avatar
I would at least loosen the 4 bolts on the frame.
Old Oct 4, 2013 | 09:20 AM
BarryG's Avatar
I dont recall having any problems doing it with the sway bar on the truck. I dont think I even loosened the frame bolts though that may very well be a good idea.
Depending on your mileage and condition you might want to go ahead and change the frame bushings at the same time which I did not since they didnt need it at the time but they do now. Apparently the 01s could come with more than one size. The biggest I have been able to find is 33mm but mine measures bigger like 35. Another thread poster mentioned the same thing he found some somewhere, though other posters said theirs were 33. I just havent made the time to follow up and find the correct size.
Old Oct 4, 2013 | 04:31 PM
Rowdy III's Avatar
What brand links are you going to use?
Old Oct 4, 2013 | 04:35 PM
Silver R/T's Avatar
They're Mevotech (made in china) with greasable ball joints.
Old Oct 4, 2013 | 04:56 PM
Rowdy III's Avatar
Thanks.
OneHigh4x4
Aug 27, 2007 07:54 PM
peski32
May 14, 2007 06:11 AM
68dodge
Jun 25, 2006 11:28 PM
Inferno Ram
Jun 11, 2006 10:53 AM
