Ceramic Brakes
Old May 20, 2003 | 04:05 PM
JImbo1's Avatar
Ceramic Brakes
I had ceramic brakes put on and drove about 500 miles. The truck is unbelievable FANTASTIC. Best brakes I ever had in MY LIFE. Stopping is SOOO much better than original brakes.<br><br>I don't know anything about them as far as being tough on the rotors, but it's worth the sacrifice even if I have to replace the rotors. I'll NEVER buy anything else, but ceramics.<br> ;D ;D
Old May 20, 2003 | 04:23 PM
drecu's Avatar
Re:Ceramic Brakes
Did you get the ones from napa? that are the Raybestos brand?<br><br>DRecu!
Old May 20, 2003 | 08:44 PM
Jetpilot's Avatar
Re:Ceramic Brakes
What brand are they and do you have a part #?
Old May 20, 2003 | 11:01 PM
Stamey's Avatar
Re:Ceramic Brakes
Ceramix for my 99:<br><br><br><br>Chris
Old May 21, 2003 | 07:08 AM
JImbo1's Avatar
Re:Ceramic Brakes
Yes, I got them from NAPA, but they were UNITED..about $75. for the pair
Old May 21, 2003 | 09:56 AM
Jrr's Avatar
Jrr
Re:Ceramic Brakes
[quote author=Jetpilot link=board=7;threadid=14960;start=0#140420 date=1053481445]<br>What brand are they and do you have a part #?<br>[/quote]<br><br>I did mine in November switched over from carbon metalics and there was no problem with the carbon metalics just trying something different. All I can say is the ceramics are even better than the hype and media advertised. Some people I have talked to have had issues with the different brands of ceramics being too thick and having to turn down rotors or put the pads on a belt sander. Mine fit perfect with no mods, mine are made by Ac Delco got em from a brake supply house. Hope this helps.
Old May 21, 2003 | 01:09 PM
JImbo1's Avatar
Re:Ceramic Brakes
I think that's one of the big deals with ceramics...NO DUST ;D
Old May 21, 2003 | 03:24 PM
HOHN's Avatar
Re:Ceramic Brakes
Ceramics are not all they are cracked up to be, sorry. If you have to stop on a LONG grade often enough you will see what i am talking about. They are very hard on rotors (not that we care). Don't get me wrong, I am sure that your results are, in fact, what you say they are. Anything has to be an improvement over OEM.<br><br>All brakes will dust. it might be more or less, but they all will dust.<br><br>If you want high-friction brakes that won't eat your rotors, then try Carbon-Kevlar (not metallic)<br><br>The Porterfield Racing Brake company makes about the bet brake pads I have ever seen. They are the cutting edge in racing brake pads, and they do make a streetable pad. They handle heat better than all others. They are pricey ($160 for all four wheels), but they are worth it.<br><br>When I last called them, I was told they now make a pad for 2nd gen Dodge HD trucks (even with rear discs).<br><br>Might be worthwhile to check them out.<br><br>www.porterfield-brakes.com<br><br>HOHN
Old May 22, 2003 | 08:10 AM
HOHN's Avatar
Re:Ceramic Brakes
Ceramic might be right for you Gary. The lack of dusting is the main reason they were developed.<br><br>I prefer max braking power, so I will put up with the Porterfields dusting (which is no worse than stock)<br><br>Different brakes for different priorities.<br><br>HOHN
Old May 22, 2003 | 09:49 PM
Stamey's Avatar
Re:Ceramic Brakes
I have had the Performance Friction heavy duty pads and now have the Napa Ceramix. Neither one has much in the way of dust. I was happy with the former, but my calipers stuck and wore them out prematurely, and when I needed the pads no one had them in stock, so I had to get the latter.<br><br>Chris
Old Jun 18, 2003 | 12:35 AM
antknee's Avatar
Re:Ceramic Brakes
I have ceramic pads too..<br><br>I love em !!!!!!!!!!!!!<br><br>They also last forever; they never wear down !!!!!!!!!!!!!
Evildiesel
May 5, 2004 09:02 PM
JImbo1
13
Apr 18, 2003 06:44 AM
JImbo1
Apr 17, 2003 06:59 AM
