Can you guys fill me in
Old Jul 25, 2006 | 09:40 AM
iker42's Avatar
Im not sure if this is in hte right spot, but can anyone fill me in on which trannys and turbos went in our trucks, specs and what years? I started to follow it at one time then kinda lost track...So is their any list or anything...
Like this Tranny/Model#/Speeds/years
Something like that?
Thanks Mike
Old Jul 25, 2006 | 09:58 AM
RowJ's Avatar
I think you will find most of your questions answered here... http://www.dodgeram.org/
Good Luck
RJ
Old Jul 25, 2006 | 12:03 PM
iker42's Avatar
that helps alttle, now anyone know the turbos?
Old Jul 25, 2006 | 12:14 PM
signature600's Avatar
94-2000 are all HX35's...but the later ones, I think in 99-00 had a smaller compressor wheel, with less blades/fins. A little more efficient
01-02 Sticks are still HX35, 01-02 Auto's are Hy35's...smaller exhaust housing for fast spool! Choke at 35psi!
Chris
Old Jul 25, 2006 | 12:17 PM
iker42's Avatar
now what exactly does a wastegate do?....i know i been around for awile, just havnt been to the turbo or trans threads....sri for the dumb questions
Old Jul 25, 2006 | 12:20 PM
A wastegate allows exhaust gas to go around the turbo wheel, so it doesn't "pickup speed!"
Basically, we can use smaller turbine housings to get better spool, then wastegate them to keep boost down to safer levels!
Makes sense??
Chris
Old Jul 25, 2006 | 12:58 PM
iker42's Avatar
Yep...Now i see a piece of rubber tubing on some turbos...like 1/2inch diameter...What is that?
Old Jul 25, 2006 | 01:00 PM
Coming from where???
Chris
Old Jul 25, 2006 | 01:06 PM
Buckshotmckee's Avatar
I believe that hose your asking about is what is used to plug the wastegate, to spool the turbo quicker and build more boost.
Old Jul 25, 2006 | 01:09 PM
iker42's Avatar
Now can that be pluged on a 24v 2nd gen?
Old Jul 25, 2006 | 01:13 PM
Yes...but not without a box/Smarty/ boost fooler to tell the computer it's only "seeing" factory boost levels!
Chris
Old Jul 25, 2006 | 01:14 PM
RowJ's Avatar
Perhaps Mike is asking about the waste gate actuator hose? (blue hose in picture)
If so, turbo pressure (cool air) passes from the turbo to the actuator (through the hose) and pushes down on a diaphram in the actuator to move the arm, which opens the waste gate at the desired pressure.
RJ
Old Jul 25, 2006 | 01:15 PM
Yup! Mine is, but you need a box with a boost fooler.
iker42's Avatar
And thats only on a aftermarket turbo?
Old Jul 25, 2006 | 01:22 PM
Nope, stock, aftermarket, anything with a wastegate!
Chris
