Camshaft?
Old Jan 31, 2007 | 10:35 PM
rollinsmoke's Avatar
Camshaft?
Is the Helix cam about the best out there, or is there something a little more aggresive. I saw the Helix 3 but it looks like it's more setup for N.O.S and a lot higher R.P.M?
Old Jan 31, 2007 | 11:42 PM
cumminsdriver635's Avatar
The 3 also requires different pistons. I know Piers will grind a cam for less than the Helix costs to what you want it ground to, but im not sure what would be best.
Eric
Old Feb 1, 2007 | 09:00 AM
Don M's Avatar
DTR Advertiser
The 3 does NOT need flycut pistons. It is aggressive, but is working well in high HP 24 valves, even under 3200 rpm.
I dont think you would find anything better and that is tested to work as designed.
Old Feb 1, 2007 | 12:47 PM
wildmanben's Avatar
hows the H3 in a 12v Don?
Old Feb 1, 2007 | 01:18 PM
cluckmaster's Avatar
I'm running a cam I bought from Greg Hogue that was custom ground by Bullet Cams to his specs. I know it's in a few very high hp trucks. One of his cams was in the 11 second truck they built up in Diesel Power mag for Hot Rod Drag Week. I would at least call and talk to him about it before making any decisions. PM me if you are interested and I'll give you contact info.
There's some other cam grinds out there that I can't speak for but I've heard others say good things about. Check out Schieds and Enterprise Engines. -Josh
Old Feb 1, 2007 | 02:20 PM
Sorry about that Don, I thought the 3 required fly cuts. Guess I was wrong.
Eric
Old Feb 1, 2007 | 03:58 PM
halerazor's Avatar
i'd say haisley,scheid or EEP for truck pulling there billet cams are pretty sweet but the journals need bored and the pistons need flycut.
drawson
May 4, 2004 12:03 AM
hustler
Mar 31, 2004 08:07 AM
al*gray
Mar 18, 2004 07:57 PM
thumper 549
Jul 27, 2003 08:34 PM
1ST GEN.
Nov 7, 2002 10:39 PM
