What's the best way to change a camshaft?
Old Mar 18, 2004 | 03:50 PM
al*gray's Avatar
Have a 1998 12 valve engine. What's the best way to change the camshaft? Do I need to pull the head?
In the Motor manual it's says something about a dowel tool to lift the tappets. Has anyone used this before? Is this a special tool or a wooden dowel?
Old Mar 18, 2004 | 05:47 PM
nascar mark's Avatar
If you are going to change the cam with engine in the truck, you will need the cam install kit. It has a tray, 12 dowels, 6 rubber bands, 1 long dowel with hook and 1 string with rubber plug. You don't have to pull the head but will have to pull the rad, condencer, intercooler and lift pump. PDR and Cummins sell the kit.
If you are going to change the cam with the engine out, you can either turn the engine on its side or up side down and not need the install kit.
Old Mar 18, 2004 | 07:57 PM
infidel's Avatar
It's basically the same as the repair for a case busted from a dowel pin.
Outline here- http://www.flex.net/~triplem/new/dowelpin.htm
t.sand
15
Dec 21, 2012 10:47 PM
C/PRD/
18
Sep 18, 2012 07:14 PM
freierj
15
Jan 2, 2009 12:00 PM
thumper 549
Jul 27, 2003 08:34 PM
1ST GEN.
Nov 7, 2002 10:39 PM
