cam or head??
Old Jul 10, 2007 | 06:11 PM
deereguy07's Avatar
cam or head??
If you were rebuilding a 12 valve motor and you had have pistons would it be better to put a 24 valve head on or put a cam in it?
Old Jul 10, 2007 | 07:56 PM
stuckey200224's Avatar
if it were me i would put the 24v head on now and do the cam later moat people would probably disagree but thats my .02
Old Jul 10, 2007 | 08:00 PM
pmtg's Avatar
how do you plan to connect the 12 valve injector lines to the 24 valve injectors?
also, not sure if a 24 valve head will properly locate the injectors to spray in the 12 valve piston bowls...im not a betting man but i dont believe that'll work.
Old Jul 10, 2007 | 08:05 PM
Mike D's Avatar
He will probably have to get a set of lines for a p-pump conversion. I believe he said he had the 24v pistons.
Old Jul 10, 2007 | 08:07 PM
Mike Holmen's Avatar
The Guru
They have kits available to convert from a 12v 7100 pump to a 24v engine. You just need to get new injector lines. I would run the 24v with the VP. Its a better daily driver. IMO .Of course if your building a maxed out HP junky truck forget the 24v head and run a 12v. They take more abuse and can with stand more heat of pulling. There better coolant flow in the head, less air paths with a 12valver.
Old Jul 10, 2007 | 09:44 PM
thekidfan's Avatar
I thought the problem was the HG? A ported head is way more improvement then a cam.....by a long shot!!
Old Jul 10, 2007 | 11:43 PM
ratsun's Avatar
I don't know Mike I would have to disagree with you on this one.
I have owned both and my 12v actually has 50-70hp more than the 24v and I couldn't be happier. I drive it every day with no issues (or worries ) no dead pedal syndrome, no apps issues, no lp worries, no code pulling, I just simply get in and drive. It consistently runs the same every time with no variations that make me wonder...what was that...
The only point I can give to the 24v is 3-5 power settings where as the 12v only has 2 but other than that I feel that a 550-600hp 12v is just as streetable as a 24v if its built right, and way more reliable to boot.
Old Jul 10, 2007 | 11:44 PM
ratsun's Avatar
Not in a engine under boost pressure.
Old Jul 11, 2007 | 12:28 AM
thekidfan's Avatar
Well when I did the cam there was very little difference, when I did the head it was a 31+ rwhp gain and probably 300* drop in egt's well worth every penny!
Old Jul 11, 2007 | 07:48 AM
Jetpilot's Avatar
Go with the cam...... A 12v head can be ported to flow more than a 24v with the proper work. You also get the larger valve stems (have seen the 24v valves break). You also would not need any conversion parts and anyone could work on it if you broke somewhere away from home. The cam will help with overall performance. Normal performance gains are not measured in peak HP but rather broader power curves. Just my $.02 worth
Old Jul 12, 2007 | 04:59 PM
deereguy07's Avatar
I had kinda thought the cam if nothing else for cost. Does anyone know of any other good cam builders besides scheid and enterprise?
Old Jul 12, 2007 | 08:39 PM
Jetpilot's Avatar
Formula 1......
etn550
Apr 1, 2010 12:12 PM
AH64ID
Jan 18, 2009 04:59 PM
BigBlue
19
Feb 6, 2007 04:02 PM
1dslram
Dec 2, 2003 12:51 PM
