Bully Dog J-Hook Spring?
Just installed my Bully Dog J-Hook. In the directions it say's to tighten up the turn buckle until the spring is 1-3/4" long. So, here goes the stupid question......How do I measure the spring? Do I measure it from the tip of the eye to the tip of the eye or just the spring section itself. I currently have it ran as tight as it will get, bottomed out and it just does not seem to be tight enough. From tip of the eye to tip of the eye it is 2-1/4" and the coil section of the spring is only 1-1/4". Any help would be greatly appreciated.
Originally Posted by Ph4tty
How bout a test drive to see when it opens and adjust it from there? Just a common sense answer from the guy with no experience w/ j-hooks =P
Another common sense answer. Due to no expirience w/ springs. Just firm enough so it does not rattle.
You will need to do trial & error.... want to set it at 32 psi boost max!
I just did the 4" turnbuckle and locked it off completely. Did not get into excessive boost on HY-35 till I got over 325 or 350 HP. At this point it really is time for a bigger turbo.
I don't think you need to worry about too much boost... where you are now.... especially since probably not running 5x5 with stock tranny. Adding more?
RJ
RJ
I don't think you need to worry about too much boost... where you are now. Adding more?
RJ
RJ
Thanks for the help.
Most use the spring to control over boosting! Let us know what you find.... good info for future reference since more people seem to be using the spring than use to.
RJ
RJ
CLeger67
04-07-2008 08:17 AM
chevkiller
16
02-16-2004 01:14 PM
Push Rod
02-08-2003 07:51 PM
