built 180 vs 215
Old Jan 6, 2008 | 10:09 PM
one54ton's Avatar
built 180 vs 215
Im just throwing ideas around...im debating on building up my 180 pump or ditching it for a 215. my plan is to run a mild to big single, fairly large injectors and a few stages of spray. what do you all suggest?
Old Jan 6, 2008 | 10:54 PM
Buckshotram's Avatar
Most people will say the 215 pump nut im pretty shure theres a few people who have have ditched the 215 and went back to an 180 pump mybe Bobcat will chime in. Ive heard the Piers pumps start out as a 160.
Old Jan 7, 2008 | 02:03 AM
cumminsdriver635's Avatar
The stock 180 will provide plenty of fuel for probably 700hp or better on spray. Unless you are wanting major power, id leave it alone. But if you are set on doing one or the other, build the 180.
Eric
Old Jan 7, 2008 | 02:15 AM
Tate's Avatar
As I understand it, theres not much left of stock parts in a stoopid pump. 160 pumps are cheaper than 215's generally, so thats why they use it.
Old Jan 7, 2008 | 07:27 AM
haloman's Avatar
Keep your 180 pump.
Old Jan 7, 2008 | 07:28 AM
97' CTD's Avatar
180.
Brandon
Old Jan 7, 2008 | 10:05 AM
Joker12valve's Avatar
Give garret a call at pure diesel power, his pulling truck is a 180.
Old Jan 7, 2008 | 08:16 PM
CL2000's Avatar
Hey Chris, Brett's truck is a 180 and Im pretty sure it will do well over 800 with the spray and its never been off the truck.
Old Jan 7, 2008 | 10:42 PM
one54ton's Avatar
Ey chad, ya i know ur bros is a 180 but I didnt know if his was maxed out or what. From what Im hearing now sounds like the truck has more in it. I think my 180 is staying in along with some Winspeed tweaking. what ended up happening to bretts truck on the dyno?
Whos running 191s? what about lazer cuts?
Old Jan 7, 2008 | 11:49 PM
thekidfan's Avatar
If your going to "build" a pump short of going all out like a stupid pump why spend your $$ on anything but a 215, if the pump is coming off spend your time and $$$ on a 215!
Old Jan 8, 2008 | 11:51 AM
95dodgectd's Avatar
don't bother ditching your 180 pump, it will be able to push the fuel you want, and deff, don't even need to have it taken off the truck either, basic things will get you the fuel you'll want.
Bram
Jun 10, 2008 08:43 AM
stock600
Feb 29, 2008 03:45 PM
12valve
Dec 22, 2006 02:28 PM
ewatts2003
23
Aug 30, 2006 06:07 PM
blitz_81
20
Jul 27, 2006 02:13 AM
