building my own trans
#61
Originally Posted by Mechanos
Yes, I was talking about the direct clutch in the OD unit.... not the front clutch (clutch directly behind the oil pump).
It doesn't look like it'd be that difficult to make something to compress the front clutch springs either. I was thinking about something along the lines of a couple pieces of flat stock and couple of spacers to clear the clutch retainer hub and a bolt to sqeeze the assembly together.
#64
Originally Posted by gunracer1
man this is great, i have not bought the tools yet. and i am all about saving money.
I'm the same way.... I'd rather spend a few dollars and a little of my time to fab something than to just plunk out the big bucks for a simple tool.
#65
hey it is not that i am really cheap, i am broke. if it wasn't for all my wheeling and dealing, making and breaking. i would never be able to afford to play with this stuff. i have more time than money. and with a wife at home and three kids, i don't have a lot of play money.
#67
Back on subject..... I just got off the phone with DTT. Looks like it's going to cost me about $2350 in parts to build the tranny I want. That includes TC, VB, Master Rebuild Kit, Billet Front Servo & Billet Accumulator and a Mag-Hytec Super Deep pan (+4 qts). I forgot to ask them what it would take to slip extra clutch discs in the clutch packs in the OD unit.
#69
Originally Posted by Mcmopar
Does anyone have any concerns that there might not be enough room on the splined section of the input shaft/hub sections that a 6th clutch "might" drop off? The 48 RE holds 5 as Justin said and is working great in the last tranny that I did. Why worry about the OD OD section? It has a lot more capacity than the direct drum does, so the direct should slip LONG before the OD section will.
Give Dave G a call, that is where I get my stuff, hell of a nice guy!!
#71
As promised, there are more in my gallery.
#72
Yes, Item 1 & 2 are slide hammers that I made to pull the pump from the tranny housing, the next is the OD alignment tool, notice that it is missing the small pilot on the end?? That is why I use the shaft. The next one that you can't really see is for measuring the depth across the OD unit, and the last one is for measuring the OD unit, that one drops down into the unit, then you measure drom the one across the housing to this one. I can also give you more info from the pictures in my gallery if you like.
#73
I got 'em all under control now....
I plan to either improvise a front clutch spring compressor or just use the shop press.
Make or buy an OD spring compressor tool to use in the shop press.
Use the intermediate shaft as an alignment tool when reassembling the OD unit.
I do have a question about the cylindrical gauge block (for determining intermediate shaft spacer selection) and the flat slotted gauge tool. Can you accurately measure the dimensions of these two pieces? What I need is:
1) Diameter of gauge block.
2) Length of guage block.
3) Thickness of slotted gauge tool.
If I know these dimensions, I can improvise the tools.
Also, what do you use for a reaction shaft bushing remover? Are you using a bought tool or something else?
Thanks again for the pics and info.
#74
I can accurately measure them for you, how soon do you need the dimensions? I use a punch to remove the old bushing. I have a bushing driver to install them.
#75
how come yall are using alignment tools?... what have yall ran into that really needed to align it all..when i rebuilt the OD i just eyeball it and it all slips right together......and to decompress the spring i used a large socket that fit over the center and a c clamp...kinda jerry rigged it but it worked...
