Which box can I stack with the Superchip?
Old Nov 8, 2005 | 12:29 PM
Flatty's Avatar
I already have a superchip tuner in the dodge. now that the tranny blew up and I am getting it rebuilt, I want to stack another box on there. Which one can I stack?
The tranny is getting built SUPER beefy, so I would like to throw some power at it. Would you guys recommend the Edge EZ, Edge Comp, TST, Quad,... I want to order one this week if possible.
Do I also have to do injectors at the same time? What will bring my EGT's down? The last thing I want to do is kill the turbo.
DIma
Old Nov 9, 2005 | 08:44 AM
Ph4tty's Avatar
No.
More air. I didn't see a pyro in your sig btw.
I don't know much, but from what I've read the superchips is an entry level fuel/timing box that also scans for codes. TST is fueling only but should stack with a fuel/timing box. You can always keep the superchips for reading codes and use edge ez/comp or mad ecm for your fuel/timing. Keep in mind that comp/tst require the wire tap
Old Nov 9, 2005 | 02:41 PM
airman's Avatar
Wink
I have a edge ez stacked on mine with the superchip that works priety nice it seems to have endless power.
Old Nov 10, 2005 | 08:37 AM
Mark Craig's Avatar
Flatty,
An EZ or van Aaken and a set of 275RV injectors will do wonders for you. Please make sure you have gauges 1st though. Call us if you have any questions etc.
Mark @ DPPI
cinch1313
Dec 7, 2010 01:51 PM
AlanF
Dec 25, 2007 04:00 PM
lcaad1249
Sep 14, 2007 12:10 PM
TORQUE BEAST
Feb 13, 2007 07:22 PM
CWICKHAM
Dec 16, 2002 06:35 AM
