both hi and low beam on ??
Old Feb 23, 2004 | 06:30 PM
dieselcrazy's Avatar
i remember quite sometime ago i saw somewhere a how - to about making both high nd lo beams both work in high beam position. it seemed like a very simple jumper wire had to be added somewhere. any1 have any idea where that article is ? had a pic and description of how to do it. i did a search but came up empty. maybe some1 knows a more specific search or where its at. thanks, scott
Old Feb 23, 2004 | 06:37 PM
Graeme's Avatar
It is commonly known as a "bright box". Maybe that'll help your search. I remember reading a thread on it some time ago, but not the details about how it was done.
Old Feb 23, 2004 | 06:50 PM
phox_mulder's Avatar
I think the jumper thing you're thinking of is to let the fog/driving lights be on the same time as the high beams.
Brite box is the only way I know of to have both high and low on at the same time.
Except, of course, driving around with your hand holding the switch at just the right place.
phox
Old Feb 23, 2004 | 06:52 PM
Borush's Avatar
Geno's Garage sells the Brite Box.
Boyd.
Old Feb 23, 2004 | 06:54 PM
i thought there was a way to do it w/out the britebox......... maybe not.. im only 32, could i be losing my mind already....
Old Feb 23, 2004 | 07:23 PM
DF5152's Avatar
no there was a thread some where the author said somthing about tying the 2 wires in the column together since when u pull the flash to pass it lights all the light.
Old Feb 23, 2004 | 08:51 PM
electrifried's Avatar
I saw that and printed it off to add it to the future projects list. The address at the bottom of the page is https://www.dieseltruckresource.com/...rite_relay.jpg
I hope this works
MnTom's Avatar
Check Here: https://www.dieseltruckresource.com/...ght=headlights
Tom
Old Feb 24, 2004 | 09:59 AM
ramcummins's Avatar
Look HERE for under $20 works great.
Old Feb 26, 2004 | 12:29 PM
rjordan's Avatar
thats what i did to, works great, no probs at all
Old Dec 14, 2004 | 10:02 PM
MnTom's Avatar
I found the post I was thinking of try looking here: https://www.dieseltruckresource.com/...ght=headlights
This is much simpler than any other way I have seen.
Tom
Old Dec 15, 2004 | 10:25 AM
infidel's Avatar
I used one of the JC Whitney $20 GMC setups on a Ford, works great.
Direct link> http://www.jcwhitney.com/webapp/wcs/...ZPpSn6wvrzY%3D
Old Dec 15, 2004 | 10:59 AM
RowJ's Avatar
Just spoke with Rattle_Rattle, the engineer in MnTom's reference thread above.
Has been 2 years and has done several trucks with no problems on any of them! The price is hard to beat....under a buck, and the Mod is VERY simple to do!
RJ
Old Dec 15, 2004 | 04:10 PM
CTD NUT's Avatar
I did have the concern about high and low beam current being drawn through the headlight switch at the same time but if it has worked for that long with RR's setup, I guess it must be fine..........I think when ever I get a moment I will do the mod on my 98.5...........I'm going to do that jumper wire mod for the fog lights to stay on w/ the highbeams - great link from Geno's site ..................
Old Dec 16, 2004 | 10:35 PM
freddy2pipes's Avatar
Pretty simple, just install a jumper from high to low circuit with a diode. Allows power from high beam to pass to low beam but not the other direction.
