Both filaments lit when on high beam FYI
Old Jan 4, 2005 | 05:31 PM
Ricktye's Avatar
Ok, I see someone did this mod on '96 and the wires are the same color, so i am assuming they will be on my '97 too. That's the good news, now for the question........ What about those of us with Daytime Running Lights (DRL) does anyone know if it'll work with them? Anyone done it?
TIA
R...
Old Jan 5, 2005 | 05:55 AM
CTD NUT's Avatar
This mod has nothing to do with the DRL's - they will function normally........
Old Jan 5, 2005 | 06:55 AM
Ricktye's Avatar
Ok, thanks for the quick reply. I did something like this on the F##d I had and the low voltage from the DRL was causing relays to constantly latch/unlatch, so had to remove the DRL module.
R...
Old Jan 5, 2005 | 09:30 AM
RowJ's Avatar
Rattle...or others
I'm confused. Are the relays needed or just nice to have?
Signed, Electrically challanged
Old Jan 5, 2005 | 10:00 AM
infidel's Avatar
Re: Rattle...or others
No, the relays are just are just a harder more expensive method to achieve the same goal
Old Jan 5, 2005 | 11:31 AM
CTD NUT's Avatar
The relays are not required for the setup to function properly but RR used some to take the load off the head light switch and provide less of a voltage drop to the bulbs........I did RR's set up and it works fine without relays but I am going to install a relay inline on the high beam circuit near the lights to give me piece of mind and minimize the voltage drop on the high beams for hopefully even brighter lights.
Old Jan 6, 2005 | 04:18 PM
gwhammy's Avatar
Just did this on my 97, worked like a charm. I think the 02 is next in line this weekend. Thanks rattle_rattle
Old Jan 6, 2005 | 05:09 PM
Ricktye's Avatar
How long have you had it run on the '97? Same color wires?
R...
Old Jan 6, 2005 | 07:21 PM
gwhammy's Avatar
Just done it today, but rattle_rattle says he has done it for over a year. Yep, same color wires. With a test light it works just like he said. I've also got my fog lights where they stay on all the time when the switch is out. The lights on these dodges leave alot to be desired. If anything goes wrong I'll tell ya.
Old Jan 6, 2005 | 07:37 PM
Ricktye's Avatar
Thanks for the update. Going to get it done as soon as I get some warmer weather. Probably do the fog lites at the same time...... Did you just cut the pin off the relay? Seems the easiest, if I can find thee right relay! 8>)
R...
Old Jan 21, 2005 | 06:49 PM
wrangler's Avatar
i have an 01 sport does anyone know if this will work i have tha above mentioned wires the violet comes on with high beams one light green does nothing the other light green only comes on when when i flash the switch with the light switch off only alsu does anyone know how to do this to the fog lights
any help would be appreciated
wrangler
Old Aug 15, 2005 | 10:46 PM
ramruff's Avatar
Reviving an old thread
Does anyone know if this jumper will work on the third gen trucks too ?? anybody tried it ??
Old Aug 24, 2005 | 04:54 PM
gradyjim2003's Avatar
RE:Solution
can you be more specific as to the wire bundle location rattle? I have a 2003 3500, when looking at the bottom of the steering column, which bundle am I looking for?
Old Aug 24, 2005 | 05:25 PM
Bobcat698's Avatar
There is a kit here:
http://www.blackclouddiesel.com/Dodge/lighting.htm
Old Aug 27, 2005 | 10:20 PM
torquefan's Avatar
Bobcat, have you ordered this kit? Just wondering what the quality is like, since there's no picture. Thanks.
