boost gauge leak
boost gauge leak
I'm in the process of moving my gauges to the a pillar from between the steering wheel and shifter. I got the boost gauge conected and installed, but now it leaks. I don't even need to look at the gauge, I can tell how much boost I'm making from the howl comining out of the a pillar. I know it is in the line, because it would hiss at times before. I thouhgt by moving it and tightening everything up, it would fix it. It did not. What do I need to do to fix the problem? The tube is plastic. I don't know if it is supposed to be flared or anything.
Originally posted by ludwick_j
Thanks. Sounds simple enough. This is a bit embarrassing but I don't do well with fittings (or wiring). Why both ends and not just the one at the guage?
More than likely the ferrule is distorted from overtightening and won't come off the hose anyway, cut off a short piece of hose with the ferrule and install a new one. 10¢ from the auto parts. You should also check the compression nut and see if it's cracked from overtightening.
On this type of compression fitting hand tight plus one turn with a wrench is plenty, any more and you're begging for a leak.
Common
May 23, 2008 05:05 PM
Tank_66
Feb 28, 2008 08:34 PM
turbomike
Dec 3, 2007 09:31 PM
CRXsi
Mar 31, 2006 07:56 AM
Bobcat698
18
Oct 22, 2005 12:27 PM
