boost fooler and builder
Where did you see a "boost builder" for the '01?
Technically, all a boost fooler does is intercept the signal from the MAP sensor and trim the signal voltage sent to the ECM. The causes the ECM to see no more than the stock max boost, while you are actually making higher than stock numbers. If the ECM saw the higher boost reading, it would throw a code.
The only way to build additional boost is to add more fuel. Most fueling boxes included a boost fooling feature, but they do make stand-alone boost fooling boxes for guys running just larger injectors or other mods without electronic fueling enhancement.
Killdmycobra
Nov 12, 2010 05:15 PM
JD311
Jan 12, 2008 07:31 PM
grecododge
Nov 17, 2007 11:03 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
