Boost Elbow
Boost Elbow
Every time i get done posting I remember another question I have.
I put in a #10 plate earlier this summer, set it where I wanted it, definately feel the gains.
But, I was in a hurry and didnt put the elbow on, Does this part account for any more performance gains?
I know i should get back in and put it on simply because it came with it, But Id also like an ieas.
Thanks
Thanks
You don't want to plug off your wastegate. The wastegate is designed originally to limit emissions by limiiting turbo boost and by doing that you can limit fuel. However, why you don't want to plug the wastegate is because you then allow for unlimited turbo boost and then unlimited turbo rpm. This can cause the turbo to either break the shaft or blow apart which is a bad thing and can cost a new motor. What you can do is adjust your stock wastegate to about 26 psi. You can push those turbos to 28 psi but I would play it safe by keeping it low. The way that you adjust the wastegate is take the e-clip off the wastegate, pull the actuator off of the shaft and screw the end piece IN about 2-21/2 turns after you loosen the two nuts holding the actuator on. Then you get shop air with a good regulator and put it all back together and put air to it. it should just start to move with the 26 psi. If not, adjust more, it is handy with 2 people.
It didn't change the bottom end. With the way mine is set up I get about 27 at full throtle up hill. The way I understand it the hx35 is good up till 35 pounds of boost, so if you don't over fuel it should be ok.
Please someone correct if I wrong.
dodgediesel
14
Dec 14, 2006 09:54 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
triplenickel
Aug 23, 2005 04:01 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
