blue pump fuel presure
by running the holley with your stock lp you will see huge pressure and may need a regulator.the holly byitself will give you 14psi and maybe a bit more wth a diferent spring,i seen close to 30psi when i installed my holly with the lp,i put in a reg and now i have 17 at idle and 11 wot,i need bigger lines to get more flow.
stevendavis
04-22-2013 09:00 PM
