blue chip vp 44 help
Old Nov 2, 2009 | 05:57 PM
x1phats10x's Avatar
gettin ready to put a vp on for the first time and wanted to know the easy way to get all the air out of the fuel lines to the injectors
Old Nov 2, 2009 | 06:55 PM
jcarrillo's Avatar
The line supplying the inj. pump at the pump, leave it a little loose and cycle the key to run the lift pump and let it run until you have a nice stream of fuel coming out without air. Then, tighten up and leave the lines to the injectors loose and turn the engine over until fuel is coming out of them. when it does, tighten the lines and it should fire right up. If it doesnt, you might want to give it a little shot of ether or rebleed the injection lines, which ever you prefer.
Old Nov 2, 2009 | 06:58 PM
Shovelhead's Avatar
Administrator / Scooter Bum
If the weather is cool, I'd skip the ether....
Red hot grid heater wires and flamable gasses don't play well together.........
Old Nov 2, 2009 | 07:01 PM
x1phats10x's Avatar
thanks sounds like a good plan to me i jsu ordered my pump today so i hope to get it before this weekend dont know how much longer my truck will make it
Old Nov 4, 2009 | 06:24 PM
Clunk's Avatar
I kept my batteries charged up with a battery charger to help with the extended engine cranks.
Always disconnect the charger before cranking.
The next time my lines are drained, I'll fill'em manually with a hypo and small line at the injector ends after connecting the pump end fittings.
I think Blue Chip will let you borrow a pump gear puller too.
Old Nov 5, 2009 | 09:45 PM
jcarrillo's Avatar
Oh yeah, forgot about the heater grid, Mine has only turned on like half a dozen times the whole time I've had the truck. That is very good advice though considering where your from.
Old Nov 6, 2009 | 05:06 PM
x1phats10x's Avatar
thanks for the help, i kinda need my heater grid here in wv gets pretty cold blue chip did send me the pump gear puller im gonna put my pump in tomorrow hope everything turns out alright
Old Nov 6, 2009 | 10:28 PM
Dr. Evil's Avatar
Heres some info that might be worthwhile looking at:
VP-44 R&R....its not that hard!!!!
By Diesel Dan
I have had this sitting in my e-mail forever.....though i would post it on here so any can get an idea of what is involved......Sorry...i didnt have a camera at the time i did this.........but PM me with any questions if needed...also i think i got a link at the bottom to a site that has pics...for any referances.....here it is:
Remove the Air horn, APPS/Bellcrank (don't need to take the cables off....just the harness) and that would get you down to the injection pump. Remove the fuel supply line and return line (17mm and 18 or 19MM) This gives them movement to get them out of the way. Use a 19mm wrench to remove the fnt 3 lines from the pump. Remove the harness from the pump.
Use a 10mm to take off 2 or 3 bolts off the hold down brackets for the lines to the intake (Towards the fnt). The other is an 8mm....it has 2 10mm bolts on the bracket, but its easier to just undo the 8mm bolt on the hold down its self.....you will see what i mean.
Ok now loosen the lines going into the head. You will do the 1st 2nd and 4th. Remove lines from motor. Now at the pump, loosen the remaining lines. Then loosen the lines at the head.....3rd 5th and 6th. The 6th is a bit hard to get too. What i always do is remove the chain bracket on the back of the head. It makes it LOTS easier to get too. (Sometimes a 3/4 or 19mm Crows foot is needed to get enough torque on it.) Once all is loose, remove lines from motor.
OK...now goto the fnt of the motor and take the Vent tube adapter off the fnt cover. I use an oil filter wrench to do this....makes quick work. Once there, take the pump nut and lock washer off. (its hard to let it happen, but dont let the washer fall in the fnt cover) Feel with your hand on the fnt of the gear by the shaft to see where the keyway is. If its anywhere below 11 and 1 o'clock, rotate the motor over to get it up somewhere between there. Use the alt bolt to bar the motor over....(rotate the alt nut counter clockwise.) Once the keyway is at the top....go on to the next step.
Remove the 4 pump nuts holding it to the fnt cover. (15mm IIRC)
There should be a lower bracket on the pump with 2 bolts that need to be removed (13mm) as well. Once you get that done, its press time. this will be the hardest part of the job. You can use the bolts off the air horn to thread into the pump gear. Put them in and measure the distance between them. I made my own press with a 1.5" x 5" piece of 1/2" metal and some metal shock absorber bushing sleeves. I took the measurements and drilled oversized holes (Allow for adjustment) in the 1/2". Then i welded the shock sleeves to the plate. Then i welded some washers on the top of the sleeves to keep the bolts from going through. Install the press and tighten up the bolts. The gear should release after a few turns. I don't use grade 8 bolts due to they bend real easy...the sock air horn bolts are a lot harder. I have used a steering wheel puller in the past....but you have to cut it down (not enough room between the shroud and pump) and its a pain to keep from twisting. I have heard people using a "Bar Press". Might want to look into that.
After you get the gear off the shaft, CAREFULLY pry the pump away from the fnt cover. Should come easy. Then make sure your key is still in the shaft. If not, look into the gear and see if its there. If not, dig with a magnet. Out of 20 or so times, i have never had the key stick in the gear or fall. So, its rare that that will happen.
Put the pump on the bench. Take the lower support bracket off. Put the old pump and new pump side by side. Look at the shaft. Clock the new pump the same as the old. Should be about 11 o'clock or so. Reinstall the lower pump bracket on the new pump. Lube the o-ring with atf or any oil.
ALSO...here is a trick that i like to do every time i install a new one. Pull the key out of the new pump. Get a punch and punch 2 divots (one on each side) onto the new key. Then use a hammer to reinstall the key onto the shaft. This will be extra insurance that the key will not fall out during reinstallation. (Note the direction the key was installed and reinstall the same way on the shaft)
Now get a mirror and position it so you can see the shaft and keyway. Line up the key to the keyway in the gear....should not be too hard. Should just slide in if you clocked it right. If it looks good, install the washer and nut and torque to specs.....my specs are "tight as hell"...but i think they are running around 75ft lbs.....do a search.
Reinstall everything in the order as you took off. This is important for the injector lines.....makes life a lot easier! Leave the 1st, 2nd and 3rd lines at the head loose to aid in bleeding air. Do not install the air horn at this time. It makes it easier to access the lines for bleeding air.
Make sure all your electrical connections are connected before you crack the key. Once you have that done, crack the key....and bump the engine. This will cycle the lift pump for about 20 seconds. Do this about 5 to 7 times. I sometimes get fuel running out the lines if i do it enough. Then try cranking the engine for about 15 seconds. See if you are getting fuel pulses at the lines. if so, tighten up the lines that are pulsing. Motor should start to catch on one or two cyls. Once it does that...tighten up all the lines and try cranking again. It should catch and run on its own.....VERY ROUGH! Do not hit the throttle pedal yet...let it run for about 1.5 mins to clear out. If it still sounds like its missing. Just blip the throttle and it should clear. I have also used small shots (Don't get too crazy!) of either to help prime the engine. Once it starts, shut off and check if it will crank back up. If good....install the air horn and your done."
Also, Diesel Dan posted some excellent How to vids of pump removal and install on Youtube - 11 videos in all I believe - make sure you check them out:
http://www.youtube.com/results?searc...rch_type=&aq=f
Old Nov 7, 2009 | 06:30 AM
Clunk's Avatar
Good post, I like the keyway dimple snug trick.
Old Nov 7, 2009 | 09:18 AM
nickg's Avatar
heres a video link as well....I like pictures!
https://www.dieseltruckresource.com/...=152404&page=3
Old Nov 9, 2009 | 08:07 AM
jcarrillo's Avatar
Yeah, I like the key dimple trick myself, I knew better that I should do it, I didn't because I was trying to hurry and I was fortunate enough to have the opprotunity to replace the front cover gasket and front seal to get the key out of the gear train. Word to the wise. That Diesel Dan video is great.
Old Nov 9, 2009 | 05:46 PM
Clunk's Avatar
Jes' thinking, you gotta remember it's a machined taper so you really can't dimple it deep...it needs full contact with the shaft and gear.
I wonder if you could lock the key in place by just make a little wet spot in the bottom of the keyway with some blue loctite and rub the key in it to activate the loctite?
tbishop1
Sep 4, 2005 02:14 PM
cowdude
Feb 19, 2003 06:20 PM
