Black Smoke
Old May 17, 2007 | 09:25 AM
Vanb's Avatar
Black Smoke
I was wondering what I can do about the excesive amount of black smoke my truck is producing? I just put DD2's 75 hp injectors in it and I had a superchip on it but i took the chip off because it was way to much smoke. What is the deal how can I reduce the amount of smoke and still make more hp.
Old May 17, 2007 | 10:25 AM
Mike D's Avatar
Why are you starting a new post? Didn't you post the same question yesterday?
Did you check your intercooler boots? Do you have a boost elbow installed to help the turbo create more boost?
Old May 17, 2007 | 10:46 AM
Gotlift01's Avatar
My guess is you are just not getting enough boost to burn that extra amount of fuel you added. 75hp injectors on stock boost settings are gonna smoke no matter what you do.......you need to pump out some more boost and I can almost bet that will solve your problem.
~Nick
Old May 17, 2007 | 11:07 AM
Vanb's Avatar
So if I get the boost elbow would that help?
Old May 17, 2007 | 11:17 AM
Vanb's Avatar
I did check the boots on the intercooler and they looked fine. At an idle should I be producing boost or not. The prob is in take off and between the gears. Oh sorry for the same post I wasn't around yesterday to talk about problem.
Old May 17, 2007 | 11:35 AM
Gotlift01's Avatar
Yeah a boost elbow will make a world of difference. But you will have to put the superchips back on ( I think they have a boost fooler, cuz if not than you'll throw codes for too much boost ). The reason it does it on take off and between gears is because of boost lag......once the turbo spools it burns the fuel and starts to clear up. But not having enough boost to clear it up, you are going to have smoke.
I see in your sig that you have a boost gauge? What kind of boost numbers are you seeing? 22psi roughly?
~Nick
Old May 17, 2007 | 11:36 AM
Gotlift01's Avatar
Ohhhh and no, you shouldn't be seeing any boost at idle. Your gauge should be on zero.
~Nick
Old May 17, 2007 | 11:43 AM
pmtg's Avatar
Originally Posted by Vanb
...Oh sorry for the same post I wasn't around yesterday to talk about problem.
at the bottom of the forum page you can click to different pages you want to view. depending on how busy the day is, your thread could have carried over to page 2.
a power upgrade and a heavy foot with low-to-no boost = smoke. might have to learn how to drive again...it gets me by accident too at times!
Old May 17, 2007 | 11:44 AM
Vanb's Avatar
Great, do you know where I can buy that Boost elbow?
Old May 17, 2007 | 12:20 PM
Vanb's Avatar
Never mind I just bought one thanks for your help.
Old May 17, 2007 | 02:02 PM
pmtg's Avatar
so, what kind of boost are you seeing? does it spike then creep down before letting off the pedal?
Old Jun 24, 2007 | 03:05 PM
JohanBolle's Avatar
Johan: 2001 3500 diesel 24 valve with turbo & "superchip??" 230K miles
Hey guy's. my truck produces a lot of smoke also & has little power. Before this forum I thought that I may need to change out my injectors but now i'm reading about some other posible causes. What would be the most logical steps for me to get this problem taken care of. Thx Johan
BTW. This is my 1st post. I'm in Phoenix AZ.
Old Jun 24, 2007 | 03:11 PM
clutch1's Avatar
what turbo?
Old Jun 24, 2007 | 03:34 PM
displacedtexan's Avatar
Get the code pulled, is it the original injection pump? Check the intercooler boots.
Old Jun 24, 2007 | 03:36 PM
chadwick's Avatar
i would pressure test the intake system before i went and bought anything
to do this take a 4 inch pvc cap and drill and tap the end so you can put a regulater on it. Also get a piece of 4 inch rubber coupler so you can attach it to your turbo. Dont forget hose clamps. Take the intake of the front of the turbo and attach the tester. Pressurize to about 30 pounds and listin for air leaks or take a bottle with soapy water and spray it on the intercooler boots.
My truck was missing on the the intake bolts and the manifold and was losing alot of boost like that
RJOS
16
Sep 3, 2007 09:19 PM
BuildingBoost
Mar 25, 2007 07:46 PM
BlackSheep5
Nov 27, 2006 07:52 PM
bensdad_canada
May 9, 2005 10:56 PM
dhe9
Nov 14, 2003 07:31 AM
