Black Smoke
Old May 15, 2007 | 11:31 PM
Vanb's Avatar
Black Smoke
I was wondering what I can do about the excesive amount of black smoke my truck is producing? I just put DD2's injectors in it and I had a superchip on it but i took the chip off because it was way to much smoke. What is the deal how can I reduce the amount of smoke and still make more hp.
Old May 16, 2007 | 12:00 AM
lovinCTD59's Avatar
If you are getting a lot of smoke, like you say. I would check all of the boost tube boots, clams, etc. to make sure you dont have a boost leak.
Old May 16, 2007 | 12:35 AM
Ph4tty's Avatar
How much boost are you seeing and is it smoking at full boost?
Old May 16, 2007 | 08:53 AM
zulusafari's Avatar
I don't know the specs on the DD2's, but are they more than a stock turbo can effectively cover? Perhaps it is time to upsize the turbo for more air. (Naturally, the previous posts are the best starting points A boost leak is cheaper to fix than upgrading turbos.) I am a bit underexperienced with injector-turbo relationships!
Old May 16, 2007 | 09:02 AM
Ryan Hyatt's Avatar
Does the smoke clear out when the turbo spools? And how much boost do you push?
Like they said first check for any boost leaks, and if there are none then maybe a boost elbow or boost fooler from BD, if theres still too much smoke then the only way to really would be a bigger turbo.!..
Personally i love the smoke and theres nothing wrong with it unless its still smokin when the turbo is spooled but if you dont feel the same way then thats the way to fix it.
RJOS
16
Sep 3, 2007 09:19 PM
BuildingBoost
Mar 25, 2007 07:46 PM
BlackSheep5
Nov 27, 2006 07:52 PM
bensdad_canada
May 9, 2005 10:56 PM
dhe9
Nov 14, 2003 07:31 AM
