Big line kit....Difference?
Old Oct 18, 2007 | 07:18 PM
Texaschevelle's Avatar
I recently installed the walbro 392 on my truck and could not be happier. As you can see in my sig, the pressure is great. Now, what benefit, if any, would i gain running the big line from my fuel filter canister to the injection pump?
Would this help keep cooler fuel possibly???
Old Oct 18, 2007 | 07:37 PM
heykw's Avatar
That is great fuel pressure I wish my fass had that much. what kind of $ for you pump set up? is it belt driven?
Old Oct 18, 2007 | 07:53 PM
It was $451 shipped to my door. And no, it is not belt driven, it is all electric. I highly recommend it.
Old Oct 18, 2007 | 08:50 PM
2500superram's Avatar
when i installed my fuel line's i actually lost pressure,but i know there is more volume.my truck has more get up and go then it did when i got it.i think my injector pump was starving for fuel
Old Oct 18, 2007 | 10:16 PM
Ph4tty's Avatar
The only thing the big line would do is increase the volume of fuel in the lines so fuel pressure would not drop as quickly at WOT. A vulcan line kit and a carter pump did fine for me at 490+ hp, but I wouldn't worry about it with an walbro pump =P
Old Oct 19, 2007 | 09:11 AM
Thanks. Kinda what i was thinking. Increasing volume, not pressure so with a powerful pump(like the walbro) the pressure would result in larger volume in the big line with little drop off at WOT. Let me ask you this, with the big line's volume, is it safe to say it would lower fuel temps at the injector pump?
Old Oct 19, 2007 | 10:36 AM
RowJ's Avatar
I would not think so. At your pressure you are already by-passing the max fuel allowed by the VP-44.
Big line kits are designed to do two things....Keep FP up a bit when adding power, and extend life of Lift Pump by reducing the cycle time. Neither of these is a concern for you anymore.
RJ
Old Oct 19, 2007 | 10:39 AM
RowJ's Avatar
Mine does. 19 psi at idle and can't pull it below 17 psi at WOT. Try a #1008 spring (I think), if that kind of pressure is your goal!
RJ
Old Oct 19, 2007 | 11:10 AM
Shovelhead's Avatar
Administrator / Scooter Bum
I installed my Glacier/Walbro on Tuesday.
Idles at 20 psi, Comp on 5X5 w/ HPVP-44 still only pulls it down to 16 psi at WOT.
I already had the Scotty Big Line kit.
steelblitzkrieg
Nov 26, 2010 12:41 PM
Mechanos
Jan 22, 2009 11:25 AM
clhumm
Dec 20, 2005 07:35 AM
RAM2940
Sep 23, 2005 06:23 PM
SuperDave4x4
Jul 9, 2005 02:49 PM
