big HP numbers
Old Jul 13, 2007 | 04:19 PM
01smokin's Avatar
big HP numbers
what r the best biggest numbers i can get out of a vp44 for sled pullin me and dad are starting a truck
Old Jul 13, 2007 | 05:00 PM
R.T.D.H.S.P.'s Avatar
That al depends on if you have a stock or aftermarket turbo, the valve springs you have, the cam you have, exhaust, intake, programmer, downpipe, injectors, transmission upgrades, torque converter, valve body, etc. etc. You get the idea. You can make as much hp as you want as long as you have the adequate fuel you need going to the VP44 IP. If you get a Glacier system and big line kit or a FASS system or the like, the possibilities are somewaht endless if you have the right mods and enough $$$.
Old Jul 13, 2007 | 05:05 PM
blackdiesel's Avatar
Registered
biggest? upwards of 700+
Call doug he will tell you how to get there
However there are a lot of guys on here that dump big bucks into their vp44'd truck and not even breaking 500.
IMHO, if you want a sledpuller, get a 12 valve
Old Jul 13, 2007 | 05:07 PM
01smokin's Avatar
that what i want but dont want 2 buy another truck unles it is a daily driver i gotmine paid off
Old Jul 13, 2007 | 05:09 PM
Rodram2002's Avatar
Yup, if you want a puller go 12 valve. you can get the RPM and fuel out of them with less work and no electronical headaches.
Old Jul 13, 2007 | 05:21 PM
Registered
To get a vp'd truck there (and keepin it running) will be like buying another truck (or more)
Old Jul 13, 2007 | 07:48 PM
TxDiesel007's Avatar
Thats the smartest thing
uve said the whole year.. Anyways, Brian is right here, some VP powered rides dont respond as well, as some 12 valves do, BUT there are a handful of 24 valve second gens in the 650-700 horse range out there without Nitrous, they do mod well tho,
BUT i perfer my P pump over a VP...
The common rail IMHO, will definately be the biggest threat to the P pumped trucks now..
Rick
Old Jul 13, 2007 | 07:55 PM
graphitecumnz's Avatar
P-Pump it then...
Old Jul 13, 2007 | 08:36 PM
Ph4tty's Avatar
Its a condition called BBS *cough* big blue syndrone
Old Jul 13, 2007 | 08:40 PM
rustyshakelford's Avatar
i cant believe you spoke of his name. im taking cover in case lightening comes to strike you down!! gotta miss the guy though
brett
Old Jul 13, 2007 | 10:56 PM
CarcajouCummins's Avatar
I have to disagree. If you are talking the Modified diesel class, then yes a 12 valve is the only option. If you are talking the street class with a single charger the hopped up 12 valves and 24 valves run neck and neck. Both have advantages and disadvantages. If you want to get a P-pump to compete with the hot 24 valves, you will need a race pump.
Are you running brush pulls, or DHRA rules?
Old Jul 14, 2007 | 04:10 AM
Ph4tty's Avatar
brett
What did he get banned too?
Old Jul 14, 2007 | 05:18 AM
IIRC big blue decided on his own to not visit and post as often as he used to. but as far as i know he isnt banned.
brett
sCreamin400
Nov 2, 2008 01:46 PM
gorms
Jun 6, 2008 09:57 PM
2whistlers
Jun 21, 2006 01:04 PM
gman07
Aug 9, 2005 04:19 PM
Shaders 24v
Aug 11, 2003 10:18 AM
