BHAF Installment
Old Jan 20, 2005 | 09:38 PM
AK2STAY's Avatar
BHAF Installment
Just installed BHAF air filter NAPA 2790 with heat shield. The air intake is making a thumping sound, is that normal?
Also wondering about water intake due to rain. Live in Southeast Alaska, it's a very wet climate. Is rainsplash and mist enough to saturate the air filter and allow water into turbo?
Thanks for the template, it worked!!!!
Shep
Old Jan 20, 2005 | 09:42 PM
phox_mulder's Avatar
Check out this thread for link and part number for a water resistant pre filter.
https://www.dieseltruckresource.com/...threadid=40319
As to the thumping, I haven't experienced it myself, but have heard of others describing the same thing.
phox
Old Jan 21, 2005 | 03:44 AM
jrs_dodge_diesel's Avatar
I have the thumping too. I wouldn't worry about it. I believe it is just harmonic resonance due to the mauch larger internal chamber inside the filter. As for the water and the filter go. I was transfered to Guam last summer. It rains a lot here. I mean a lot. My filter is just fine. Kinda dirty. I am replacing mine soon.
Old Jan 21, 2005 | 09:41 PM
kevellis32's Avatar
Are you talking about the thumping that you get after you let off the gas really quick at a higher RPM? If so, that is normal, my mechanic buddies tell me that its the difference in air speed being thrown into and from the turbo
Old Jan 22, 2005 | 01:44 PM
Paul Winey's Avatar
If it's a metallic sound then the heat shield could be hitting against the upper shock bolt. I slipped a short section of rubber fuel tubing over the top to provide some cushioning. Mine would rattle from the shaking when I shut off the engine.
Rickcher
Sep 2, 2009 05:08 PM
Marine
113
Nov 6, 2007 06:24 PM
Ace
Oct 31, 2007 06:46 PM
DF5152
Mar 27, 2003 06:11 PM
