BHAF Install
The Napa part number is 2790 for the filter. When you get it, you need to find a piece of 4" pipe to insert into the end of the filter to stiffen up the joint so it can't collapse when you clamp the intake hose onto it. I used a short piece of 4" exhaust pipe left over from my exhaust.
Then you just pull out the stock airbox and lay the BHAF in it's place. Also not a bad idea to buy or fab up some kind of heat shield to deflect at least some of the heat from the turbo so you're not running off of the hot air.
I can get pics of my shield if you're interested.
Thanks for the info!!
I planned on making a heat shield, seen one on e-bay, but I know I can make one cheeper than $60!
What about a mount, does the filter need to be attached to anything to keep it from moving around?
The BHAF will lay on top of a hard A/C line without a heat shield or other support. I cut a piece of ¼" plywood that mounted on 2 of the airbox studs. I clamped the filter to the plywood.
I also used a piece of plywood and put my heat shield under it. I countersunk the plywood so the nuts wouldn't stick up and put a hole in the filter and the filter just sits on top of the plywood and the hood insulation puts slight pressure on it to hold it steady.
Mechanos
25
Oct 21, 2004 02:50 PM
WJB
Apr 15, 2004 01:49 PM
phox_mulder
19
Dec 24, 2003 02:22 AM
