Best way to Launch a DTT tranny
Old Jul 11, 2003 | 02:21 PM
hellotbone's Avatar
Ok Im off to the track next weekend providing my truck is painted.<br><br>What is the best way to launch my truck? How much boost, just hold the brakes what is the procedure.
Old Jul 11, 2003 | 02:28 PM
KatDiesel's Avatar
Re:Best way to Launch a DTT tranny
[quote author=Jamie Attridge link=board=7;threadid=16955;start=0#158896 date=1057951265]
[/quote]
Since you have 2wd.........
start off......stage, hold the brakes try to build 8 to 10lbs of boost and then floor it when you release the brakes on the 2nd yellow (out of 3) and your off. You'll have to play with different boost levels on launch depending on traction.......you might just spin them too much at 10psi.....
Did you ever get your drag comp? I'd be curious to see where your 3/4 shift occurs now RPM wise (at the track).
Old Jul 17, 2003 | 09:20 AM
hellotbone's Avatar
No drag comp yet still painting! Once its back I have an engine driven pump to put on there from onboard air then I will tinker more with the box and stuff this winter when its away!
Old Jul 17, 2003 | 06:54 PM
Edward's Avatar
Jamie <br><br>You might try a trebuchet if you want to get some distance out of that thing. <br> ;D <br><br>Edward
Old Jul 17, 2003 | 08:21 PM
phox_mulder's Avatar
And for the Trebuchet Challenged, a link.<br><br>http://www.trebuchet.com/<br><br><br>phox
Old Jul 18, 2003 | 06:57 AM
hellotbone's Avatar
[quote author=Edward link=board=7;threadid=16955;start=0#161168 date=1058486097]<br>Jamie <br><br>You might try a trebuchet if you want to get some distance out of that thing. <br> ;D <br><br>Edward<br>[/quote]<br><br>What is that supped to mean?
Old Jul 18, 2003 | 07:22 PM
MDW's Avatar
MDW
With street tires all I can do is 3-4psi off the line.<br>Good luck, and hold the brakes HARD.
Old Jul 19, 2003 | 09:26 AM
GO 4LO's Avatar
You asked how to LAUNCH a DTT tranny - he's playing with the words on ya .<br>Chris<br><br>[quote author=Jamie Attridge link=board=7;threadid=16955;start=0#161323 date=1058529460]<br>[quote author=Edward link=board=7;threadid=16955;start=0#161168 date=1058486097]<br>Jamie <br><br>You might try a trebuchet if you want to get some distance out of that thing. <br> ;D <br><br>Edward<br>[/quote]<br><br>What is that supped to mean? <br>[/quote]
Old Jul 21, 2003 | 08:46 AM
hellotbone's Avatar
Ah not I get it had to read between the lines!<br><br>Ok best way to take off! <br><br>I have a question its all I can do to keep the tires from spinning at 10 PSI should I just hold the brakes harder or will it cause damage?
Old Jul 21, 2003 | 10:09 AM
GO 4LO's Avatar
Do they make a trans brake?<br>Chris
Old Jul 21, 2003 | 12:18 PM
KatDiesel's Avatar
[quote author=Jamie Attridge link=board=7;threadid=16955;start=0#162246 date=1058795196]I have a question its all I can do to keep the tires from spinning at 10 PSI should I just hold the brakes harder or will it cause damage?<br>[/quote]<br><br>No it won't help if you hold the brakes any harder, you'll jsut continute to spin once you release them. If you do hold it &quot;harder&quot; and give it more fuel thats when things snap.
Old Jul 21, 2003 | 12:19 PM
KatDiesel's Avatar
[quote author=GO 4LO link=board=7;threadid=16955;start=0#162273 date=1058800146]<br>Do they make a trans brake?<br>Chris<br>[/quote]<br><br>Not one for the 47RE that I know of, I am sure somebody somewhere may have one in some little town.
Old Jul 21, 2003 | 02:24 PM
hellotbone's Avatar
Thanks Kat so just let em spin or take it to say 8 PSI instead?
Old Jul 21, 2003 | 03:25 PM
BigBlue's Avatar
That's what I'd do. Start dropping the PSI until you get maybe a little chirp off the line and then it hooks.
Old Jul 21, 2003 | 07:28 PM
98rammer's Avatar
[quote author=GO 4LO link=board=7;threadid=16955;start=0#161763 date=1058624792]<br>You asked how to LAUNCH a DTT tranny - he's playing with the words on ya .<br>Chris<br>[/quote]<br><br> not again..<br><br>i'd say that it's safe to say that 10 pounds of boost is still too much on stock tires. now...don't you wish you had 4wd now?<br><br>Tom
