best track bar for the money
Old Apr 22, 2008 | 06:10 PM
bullboy85's Avatar
ok well haveing the ball joints done which means i need an alinment after so i figered this would be a good time to do the track bar too. who has the better bar for the money?
Old Apr 22, 2008 | 06:22 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Thuren Fabrication.........Hands down.........
Old Apr 22, 2008 | 06:43 PM
bullboy85's Avatar
and that helps the wandering when driving down the road right?
Old Apr 22, 2008 | 06:46 PM
dieselman2300's Avatar
Agreed Thuren.
Old Apr 22, 2008 | 06:53 PM
JPR Ram's Avatar
Yeah, his trackbar will solve stock trackbar issues. Well, as long as the rest of the steering componates are in proper condition and the alighnment is on, yeah, the Thuren track bar will help keep your truck straight. It will also out live several stock trackbars; and when the time comes, they're rebuildable.
Old Apr 22, 2008 | 06:55 PM
bullboy85's Avatar
ok how do u know when u need a new one then? i think i still have the original on my truck
Old Apr 22, 2008 | 07:05 PM
JPR Ram's Avatar
Well, that's easy. Fire upo your truck. Have someone turn the steering wheel lock to lock. Now while you're laying under the front bumper, look where the trackbar mounts. On the driver side it'll be at the frame and on the passenger side, it'll be at the axle. If it's worn, it will "pop" around at the frame mount. That's the most common thing.
Old Apr 22, 2008 | 07:10 PM
bullboy85's Avatar
haha easyer said then done, some reason its hard to turn lock to lock while the trucks not moving. thinking pump? its no problem driving so i havent got to it yet,
Old Apr 22, 2008 | 07:18 PM
JPR Ram's Avatar
Yeah, that does sound like the powersteering pump is going out. But you do need to turn the steeringwheel in order to see the trackbar moving around. Just tugging and pulling on it would do. There is just too much weight on the front-end for a hand job............ That really doesn't sound good, does it???........ But that's what it amounts too. Trying to use nothing more than your hands won't work.
Old Apr 22, 2008 | 07:30 PM
bullboy85's Avatar
ya that does sound bad. im trying to get this truck rolling just as good as a new one, power and the steering seem to be all i need to do it, know what im doing about the power steerings what im still working on. thinking of the track bar, the bracket to hold the box tighter, new 3 turn lock to lock box and i guess a pump sence it seems to be going out too. just where to start is the problem
Old Apr 22, 2008 | 08:10 PM
moparlvr's Avatar
Thuren Fab . great unit
Old Apr 22, 2008 | 08:31 PM
scottsjeeprolet's Avatar
Autozone lifetime warranty Track bar. Can't beat that and pretty cheap. Mine's been on for over a year now.
Old Apr 22, 2008 | 08:48 PM
Big Blue24's Avatar
You don't need to turn it lock to lock, just have some one turn it back and forth a few inches, that is plenty to make it move if it is bad.
It's easy to tell when it's bad, whenever it gets more than 20K miles, it's bad.
If you buy a cheap aftermarket replacement, Autozone in my case, you get to opportunity to replace it free of charge every 15K miles when it wears out. I'm on my third one and while I'm getting raster at changing it...10 min job... it is getting old and I will put in a $$ aftermarket one soon.
Old Apr 22, 2008 | 08:52 PM
BigB82789's Avatar
If it don't want to turn without moving, why not set it on jackstands?
Old Apr 22, 2008 | 09:52 PM
bullboy85's Avatar
what? does that make sence?
