Best Lift to go with
Old Jan 5, 2006 | 04:56 PM
randylamarr's Avatar
OK guys I need some good opinions on what Lift to put on a Crew Cab 1998 12v with a Manual tranny. Whould also like to see a couple of pictures of trucks with around a 4-6in lift on 33s
Old Jan 5, 2006 | 05:38 PM
AggiePhil's Avatar
Repeat after me... The best lift is no lift, the best lift is no lift, the....
Old Jan 5, 2006 | 06:55 PM
Cowhand's Avatar
33's will fit on a stock truck.....it'll look like a pregnant roller skate with 33" tires and 4" of lift.
Is it a mall crawler or are you gonna beat on it?
Old Jan 5, 2006 | 07:05 PM
99 cummins's Avatar
I run 33" Truxxus on my stock height truck. I am looking for a 2" lift right now so I can go 35" next. But I don't get any rub at all on the 33".
Old Jan 5, 2006 | 07:16 PM
CASMOKIN's Avatar
Agreed, get a leveling kit and you can go up to 35's, thats what I did (pics in my Gallary). And you'll save a couple grand, which you could put towards some other bomb's
Old Jan 5, 2006 | 07:45 PM
AggiePhil's Avatar
Yeah, that's what I do too. Also, the savings is more like a FEW grand, since IMO, putting a lift on your 4x4 will wind up forcing you to spend another couple thousand dollars to fix problems that arise as a result.
Old Jan 5, 2006 | 08:33 PM
BigBlue's Avatar
Skyjacker 4.5" lift, 315/75/16 nitto terra grapplers, 16x10 mickey thompson wheels. So far it's been a good lift. I did end up having to replace the track bar (but who doesn't) and put ladder bars on the rear to keep the axle wrap under control (dang add-a-leafs). The ride is no worse than stock and the truck handles very flat (AggiePhil can attest to that one). I've wheeled it a couple of times and it flexes really nicely and the tires don't rub at all no matter how much flex is in the suspension.
Old Jan 5, 2006 | 11:07 PM
mx572000's Avatar
I Put A 3 Inch Tuff Country Lift On Mine. The Truck Lifted 3 Inches In The Front And 1.5 Inches In The Rear. 35's Fit Easily And Look Like They Fit The Truck. The Only Problem Is The U-joint At The Carrier Occasionally Needs Replaced.
Old Jan 6, 2006 | 05:17 PM
shawn085's Avatar
mx572000,
What does tuff country do on the rear to lift it 3"? Taller blocks or diffrent spring packs.
Old Jan 6, 2006 | 05:53 PM
shoe's Avatar
rear add a leafs they come with a leaf and bolt and the only down side is the coil spacer for the front they do not use a longer spring.
Dodgewincity
15
Jun 12, 2008 09:26 PM
5.9Excursion
Nov 21, 2007 06:50 PM
FMB
Feb 3, 2007 05:34 PM
j28s
Sep 9, 2003 05:20 PM
SouthTex
Jun 12, 2003 09:38 PM
