Best Fuel Pressure Guage for least money?
Old Aug 5, 2006 | 12:06 AM
Lardog's Avatar
Cool Best Fuel Pressure Guage for least money?
Lost VP-44 and don't want to lose another. The guys at MWFI have a safety light that comes on when pressures drop below 8 psi. This whole set up cost I think $86.00. Any cheaper/cooler looking route anyone can suggest?
Old Aug 5, 2006 | 12:18 AM
abbeyinc's Avatar
Take a look at Westach. Good looking, lightweight, and not too expensive.
Old Aug 5, 2006 | 07:14 AM
Marine's Avatar
Veteran: Marine Corp
Check my sig. It's a little more than that light, but well worth seeing exactly the pressure you have.
Old Aug 5, 2006 | 07:16 AM
dieselbeef's Avatar
Muted User
paid like 260$ for an autometer electric gauge and banjo bolt. best setup. no air guage not a light...steering wheel pod.
Old Aug 5, 2006 | 07:18 AM
Marine's Avatar
I think I paid about 120.00 including the cubby hole mount. I'll check my receipts and get an exact price if you PM me and remind me.
Old Aug 5, 2006 | 12:33 PM
infidel's Avatar
How about $11 for this high quality Stewart-Warner mechanical gauge?
http://www.surpluscenter.com/item.as...atname=engines
Just add less than $10 worth of plumbing, no isolator, for a problem free set up.
Old Aug 5, 2006 | 04:40 PM
cumminsdriver635's Avatar
How important is it to have an isolator in the system. I put a FP gauge on for my buddy with the isolator, but I wouldnt mind to have a FP gauge in my truck, and that stupid isolator costs too much to suit me. I dont like the idea of having fuel in the cab, but I really dont see it hurting anything. Any opinions?
Eric
Old Aug 5, 2006 | 05:44 PM
Timmay2's Avatar
Im sure alot of people run mechanical gauges without isolators. But theres always the possiblity of a gauge failing or a line leaking, and spraying fuel all over... not common for a gauge to rupture, but it does happen.
Depending on if you want to race, some places do not allow fuel in the passenger compartment, and require an isolator w/ braided steel lines on firewall. Depends on their track rules. Some also dont allow that silly plastic oil pressure line either, it would have to be braided steel.
Really only comes down to can you put a price on safety?
I suppose you could always sell your airbag and put that money towards an isolator? lol
Old Aug 5, 2006 | 05:47 PM
lsgibb's Avatar
I'm running the Westach electrical fuel pressure gauge as well. It works great and you can get it from geno's garage for under $100.
Old Aug 5, 2006 | 06:44 PM
infidel's Avatar
My experience has been that most isolators used on diesel engines fail within the first 1000 miles, leak internally and allow fuel into the cab without your knowledge.
I think you'll find quite few folks here don't use an isolator. Best bet is to install a needle valve at the head of the line so if there is a leak it can be shut down.
If you use Permatex #2 instead of teflon tape for thread sealant and don't go overboard tightening down fittings a leak would be rare.
Old Aug 5, 2006 | 07:52 PM
P.J's Avatar
P.J
I had an Isspro, straight mechanical. I will be running the same thing (no isolator), cept maybe the Optix line in the new truck.
Old Aug 5, 2006 | 08:01 PM
Dieselcamper's Avatar
I've been running a fuel pressure gauge with no isolator for
2 years with no problems. Needle valve and steel braided line
to the gauge rated for 500 psi. Lift pump puts out 16 psi , do
you think the hose will hold up under that much pressure
Old Aug 5, 2006 | 08:07 PM
P.J's Avatar
P.J
I remember reading about guys using grease gun hoses There was like 2985 psi safety factor
I will be running braided inside my cab this time around, I was all nylon tubing sheathed in NAPA fuel line on the old truck.
Old Aug 7, 2006 | 03:16 PM
supr's Avatar
Thumbs up
DiPriocol, about $50 for the gauge, from DPP. Napa has a copper line gauge kit that seems to eliminate the need for a needle valve, abot $10 for the kit. You should be OK without the issolator, many think more trouble than they are worth.
Old Aug 7, 2006 | 09:55 PM
Rhino's Avatar
I got my Nordskog electric gauge for just over $100.
