Best fuel pressure gauge
Old 09-20-2005, 07:22 PM
phox_mulder's Avatar
Originally Posted by d0dg301
Alright I don't want to here any snickers, but where might someone find their vp44 on an 01?
Passenger side of the engine, towards the front.
Lots of metal lines going to and from it.
(snickering on the inside)
phox
Old 09-20-2005, 08:15 PM
Sea01Cummer's Avatar
Could someone please elaborate on the needle valve and maybe a picture. What is the general idea if the line burst the needle valve closes cutting the fuel off to the cab?
Thanks Steve
Old 09-20-2005, 08:21 PM
Here's one installed on a '99.
Its the brass thingy right on top of the fuel filter cannister top.
It doesn't close itself off, but if you do spring a leak at the guage, you can close off flow manually.
It also serves as a snubber.
You close it completely, then open it just enough that the guage registers.
Here's one installed on a 2001.5 (same setup you'd use)
It goes on the bottom of the fuel filter.
phox
Old 09-20-2005, 09:07 PM
aaah ok i know what you are talking about.
Steve
Old 09-21-2005, 12:24 AM
Dr. Evil's Avatar
Originally Posted by Sea01Cummer
CWhat is the general idea if the line burst the needle valve closes cutting the fuel off to the cab?
Well, the valve does not close itself...that would be up to you. The needle valve mainly acts as a pressure snubber of sort and dampens the pulses from the lift pump and VP-44....as well, it will allow you to shut off the flow to the guage and still run the truck (if the guage takes a dump).
Old 09-22-2005, 03:40 PM
Moose10's Avatar
The above pic of the '01.5 is on my truck before I put the FASSII on. It's essentially still the same setup, but no more bajo bolts. The line going to the gauge screws into a 90* fitting that has a tapped hole in it.
I used 1/4" ID 300psi rated hydraulic hose from NAPA (overkill) for the gauge hose, and got all the hardware from there too. btw, I think I used 7' of hose.
More pics in the gallery....
dodgeguy71
17
01-19-2012 12:52 AM
frmll300
04-09-2007 08:15 AM
Dusty Ratcliff
02-12-2007 10:29 AM
HappyGA
02-04-2005 09:10 PM
Scrambler250
02-17-2004 01:22 PM
Quick Reply: Best fuel pressure gauge
