best fuel pressure gauge for the least $$
Old Feb 11, 2007 | 05:47 PM
Dusty Ratcliff's Avatar
what are your thoughts on the most cost effective FP gauge for the 01'???? I'm really considering the Glacier kit for it in the next few months, but for the time being I'd really like to be able to monitor the FP?? what's the cheapest route to take that's still a good reliable setup???? I'll be running Banks boost/pyro, but the gauges matching are not a big deal to me anyway, I'll probably put it under the dash anyway, thanks alot, Dusty
Old Feb 11, 2007 | 05:50 PM
HOHN's Avatar
I like the liquid-filled house brand cheapos from Jegs or Summit.
They are 1.5" diameter (fit in the tweeter hole) and have a standard 1/8" NPT port on the back.
JH
Old Feb 11, 2007 | 05:52 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Hey Dusty here is mine it is from Vulcan performance "test" guage "temporary installed" It comes with 6ft of hose which was plenty to go from the shrader on the inj pump and i just picked up a simple bezel guage pod from napa.
This is the photo at the inj pump
https://www.dieseltruckresource.com/...0&ppuser=23874
This is were its mounted
Vulcan
http://www.vulcanperformance.com/ser...w-fdsh-/Detail
Of course I changed the end fittings so i had to take the core out but i dont see a prob with leaving the core in imho
If you get really carried away you can even make a mechanical liq filled gauge light up
Old Feb 11, 2007 | 05:55 PM
thanks guys, what kind of $$ are those setups?? thanks alot!!!! Dusty
EDIT!! my bad I missed that last link Dodgecowboy, that's the kind of $ I'm talking about!!! thanks, Dusty
Old Feb 11, 2007 | 05:57 PM
DTR's Cow Boss
mine was probally around 55-60 with the bezel pod from napa
Old Feb 11, 2007 | 06:21 PM
dzlfarmboy's Avatar
Just get a guage and a boost tube kit and the hollow banjo bolt should be about $60
Old Feb 11, 2007 | 06:31 PM
infidel's Avatar
Pretty hard to beat $9.95 - $12 for an AutoMeter Industrial or S-W from here
http://www.surpluscenter.com/sort.as...s&keyword=NFGA
You might not find one that says fuel on it but any water, oil or air pressure gauge will work just fine.
Old Feb 11, 2007 | 08:23 PM
thanks infidel, I like the looks of those prices alot!!!! what would be the best route for hooking it up?? do they sell tubing & such there as well????? thanks again, Dusty
Old Feb 12, 2007 | 02:29 AM
Ph4tty's Avatar
Once again I just want to say you are the man Infidel! I went ahead and
ordered a 0-60 autometer so I can swap out my 0-15 autometer. Like $15 shipped
Old Feb 12, 2007 | 10:29 AM
infidel's Avatar
They might, here's their index http://www.surpluscenter.com/prodInd...07021118274311
You can probably get everything you need to hook it up at an autoparts store for a good price also.
Nor_Cal_Angler
16
Jun 5, 2007 08:04 AM
Gman_dodge
Oct 14, 2006 08:17 PM
Lardog
17
Aug 7, 2006 11:07 PM
turbotoys
Mar 31, 2003 01:12 AM
