Best 24V block?
Old Sep 19, 2007 | 02:02 AM
Munchies's Avatar
Best 24V block?
What is the best series of 24v blocks. I am starting a new build and am going ground up. What should I look for..
Old Sep 19, 2007 | 02:10 AM
HOHN's Avatar
Well, the rumor is that the "Mexican" blocks cast by Teksid are a little tougher than the "Tupy" Brazilian blocks that are identified by the "5x" series: 52, 53, 54, 55, etc.
Real world, I think anything other than a 53 block would be just fine. I suspect there's enough variance from one sample to another that a sonic check would matter a whole lot more than anything stamped on the block or what country it was poured in.
Mopar big blocks also have some rumors associated with them, like you shouldn't use a 1976-1978 big block for performance. Truth is, these blocks are often tougher and have thicker walls than many of the coveted "muscle car" blocks shipped with 6-pak cars and so on.
The point is that a sonic check is the only way to know for sure.
Justin
Old Sep 19, 2007 | 07:30 AM
Mike D's Avatar
I think I remember reading something about the STORM block that said it was pretty tough.
Old Sep 19, 2007 | 07:48 AM
CTD03's Avatar
55 is strong
Old Sep 19, 2007 | 07:53 AM
Tiger Rag's Avatar
Always read that 01 and 02 Mexican blocks are the strongest. They'll have a series of small #'s cast into the block. Dissimilar from the large cast 2 digit blocks in the 50 series.
Old Sep 19, 2007 | 08:07 AM
Mike D's Avatar
Here is a good link with info about block put together by DTR member Stamey.
http://www.stamey.info/Truck/Cummins53BlockFAQ.htm
Old Sep 19, 2007 | 03:22 PM
HOHN's Avatar
Good link-- and thank to Stamey for compiling that.
Looks like my late-build 2002 has the "bad boy"-- a late production Mexican block.
To bad it has an HO pump that will never challenge it's strength
Old Sep 19, 2007 | 08:39 PM
Gabe32's Avatar
why don't you run a common rail block? They are stronger than any 12 or 24 valve block.
king5335
26
Jan 17, 2010 07:57 PM
buddy26
16
Jan 14, 2009 07:29 PM
MDLP412
Feb 4, 2008 04:35 PM
Bubspc
Jul 27, 2007 10:32 PM
24Vford
Jan 2, 2007 11:14 AM
