Belt Driven Lift Pump
Old Mar 23, 2008 | 05:06 PM
  #31
HOHN's Avatar
Brake Specific Fuel Consumption. It's a measure of efficiency, telling you how much fuel the engine must burn to make a certain amount of power.
In this case, it means the CTD burns .38 lbs of fuel per horsepower per hour.
So it would burn 3.8# of fuel making 10hp for one hour, or one hp for ten hours.
The lower this number is, the more efficient is the engine. .38 is pretty low-- gas engines are typically in the .45 range or worse.
jh
Old Mar 24, 2008 | 12:57 AM
  #32
Fishin2Deep4U's Avatar
I understand what you are syaing. My point was that many folks in the manufacturing side will say the GPH flow rates are needed as the pressure increases, GPH drops.
But I am with you. There's only so much fuel at any pressure you can push through the system.
Dave
Old Mar 24, 2008 | 07:52 AM
  #33
91rangerturbo's Avatar
Originally Posted by dzlfarmboy
The MITUSA's are what we carry, Opie of Intelligent Enginering Is the designer of the pump and Came up with the RASP years ago and that was tied into with DTT as he USE to make hard parts for them and they had a falling out so he designed a even better version with aluminum pulleys and a few other upgrades.
17 Psi at Idle and goes up to about aprox 21psi with RPM change
Here's an installed pic of one
Brett
Thanks for the informative post brett. Interesting design for sure.
Old Mar 24, 2008 | 01:18 PM
  #34
paulb's Avatar
I've had a RASP on for ~128,000 miles now. Still with the orginal belt.
Paul
Old Mar 24, 2008 | 01:23 PM
  #35
mattn124's Avatar
Thanks Paul, and everyone else who chimed in without drama.
I have an airtex pump I got from O'Rielly's that looks good. I've read a few positive things about them on here. It says it's a re-designed pump, it's a different shape than the p.o.s. carter pumps I've been using.
Also, the pump is surrounded in a rubber isolsting material I assume to help against vibration.
One problem,, I have already moved my lp with a vulcan big line kit,, and the fittings on the airtex pump just wont work with it, and my local napa couldn't find me the right ones so I guess I'm screwd for a couple days.
Old Mar 24, 2008 | 01:24 PM
  #36
mattn124's Avatar
I think I will start saving for one of the belt drive systems, I just don't trust any of these electric ones anymore.
NICE_N_EEEZ
68
Jan 7, 2017 04:11 PM
hitcb1789
Jul 11, 2010 02:34 AM
JAyers
Sep 2, 2008 11:25 PM
24Vford
Apr 14, 2006 07:44 PM
spitzair
Dec 27, 2003 05:21 PM
